S10 4,3L runs well in reverse not in drive or neutral
My distributor and/or rotor failed while driving.
Replaced them, and car still wouldn´t run.
So a friend told me to replace the spark plugs.
I did, and the car runs now on idle and in reverse.
If I try to throttle in neutral or in drive it revs up to about 1000rpm and starts to stumble when engine is at normal temp.
When cold I could rev it in neutral too.
Before the distributor failed car ran great.
Anyone got any ideas what the problem is.
Before I replaced the plugs I read engine fault codes and there were none.
Well. I really do think I did mount them good.
I will check with timing strobe tomorrow.
And I will check youtube on how to do that.
Oh do you mean the ignition wires?
They should be right since I could easily cet the car in very nice acceleration in reverse.
Well the wires beeing crossed dont explain why the engine works fine in reverse
Can I have damaged something towing it 10km.
Read about that after the towing?
I didn´t disconnect the driveshafts.
timmysouthpark
November 4th, 2014 2:16 PM
nicknitro125
Silverado & Fullsize Pick-ups
August 27th, 2013 7:53 PM
Cretaccir
June 13th, 2013 1:00 PM
desolate_dreamer
January 24th, 2012 1:55 PM
