Lost the BCM, can I still bypass passlock 2?
Hello,
My Dad and I are working on a project, it's a 1952 Chevy body swapped onto a rolled 2001 S10 chassis with the 4.3 V6 automatic that ran and drove to where it sits.
The 52 body is on and we just finished the wiring and wanted to fire it up. It turns out my dad threw out the BCM since majority of the wires to it were for things like power locks or power windows, that we don't need anymore!
I'm familiar with the passlock 2 system, and have bypassed it using the fuse between the yellow and ground to add remote starters to other trucks. Now with the BCM gone forever, adding a fuse or any other sort of bypass won't work since the reference voltage in the red wire and the systems programming is lost with the BCM. The red wire was cut at the BCM connector.
The truck starts and runs fine if you prime it. If you try to start it on it's own, it may fire for 1 second and then die. Classic passlock symptoms according to my research
So my question is, what happens after the BCM? Some research indicates the passlock system was cutting out the fuel pump. So I hotwired the fuel pump, and that didn't solve the problem. Is there something else going on in the system, maybe a signal to the fuel spider? We've now got a new fuel pump and spider, and with a gauge see 50 psi of fuel at the engine.
Cheers
Cheers
Passloc bypass
Hello,
Cheers
Cheers
Hi Cow0609,
This wouldn't work since the third wire (red) to the BCM was cut and therefore had no reference voltage.
The solution was to take the PCM to a local tuner who programmed it to not need the security system.
Starts, runs and drives good now
tech2 (June 7th, 2023)
hicksvilleshick
March 15th, 2021 1:39 PM
Jason Steady
Express & G-Series Vans
March 15th, 2019 2:08 PM
