service engine soon light - Chevrolet Forum - Chevy Enthusiasts Forums
ken1950's Avatar
August 2nd, 2011, 6:09 PM   #1
I'm new here and you've probably heard this many times. Can you pull your codes without a reader???? If so how.. Don't have a book yet, but will ordering one soon. My (service engine soon light ) came on today . I checked the gas cap and disconnected the battery and reconnected to see if the light would go off . The light came on as soon as i turned the key on. Any help would be really nice (i checked the PVC valve and its good) 2001 chevy s-10 pick-up v6
kevinkpk's Avatar
August 2nd, 2011, 6:55 PM   #2
Posted By: ken1950 I'm new here and you've probably heard this many times. Can you pull your codes without a reader???? If so how.. Don't have a book yet, but will ordering one soon. My (service engine soon light ) came on today . I checked the gas cap and disconnected the battery and reconnected to see if the light would go off . The light came on as soon as i turned the key on. Any help would be really nice (i checked the PVC valve and its good) 2001 chevy s-10 pick-up v6
Don't think so with an OBD11, get a cheap scanner or take it to an auto parts store that will scan it for you.
dab11999's Avatar
August 3rd, 2011, 11:53 PM   #3
There is a way, but I'm not certain about yours. The check engine light flashes any active fault codes. Something like turn the ignition switch on and off 3 times, leaving it on the third time. It will flash a beginning test code of 12, which is one flash then two flashes. Ends with code 12 also I think. Something like code 32 would be three flashes then two flashes. It's not a precise diagnosis, but it gives you a starting point.
ken1950's Avatar
August 4th, 2011, 8:01 AM   #4
Posted By: dab11999 There is a way, but I'm not certain about yours. The check engine light flashes any active fault codes. Something like turn the ignition switch on and off 3 times, leaving it on the third time. It will flash a beginning test code of 12, which is one flash then two flashes. Ends with code 12 also I think. Something like code 32 would be three flashes then two flashes. It's not a precise diagnosis, but it gives you a starting point.
Thanks i'll give that a try before i buy a reader. No local places will read it without charging you
Tags
Sponsors
  • Ask a Question
    Get answers from community experts
What's your question?
Send
