starting and dieing issue
hey need a little help.... got a 96 S-10 4.3L....75,000 miles
it recently died and wouldnt start....replaced the Fuel pump and the Fuel Pump relay (glovebox) now it starts right up and runs but it dies after a few minutes, it will start right up and run again tho...
I am wondering if I am missing something
s10 starting and dieing issue
I have also just replaced the Ignition Control Module and it started....but died 10 minutes later,,, then replaced the ignition coil, no start,,,and seeing I had a rotor and dist cap (new) I installed them to
so now I have replaced the fuel pump, fuel pump relay, ICM, coil spark plugs, spark plug wires, distributor cap and rotor... have 60 psi fuel pressure
Found the issue
well....after much reading and researching and testing and testing....
we went out and got a Crankshaft Sensor Module/switch.... took out the one 10mm bolt reinstalled the new switch whallaaaaaa
truck started and runs great
why didnt that throw a "CHECK ENGINE LIGHT"
Kodytruckguy
December 2nd, 2014 5:59 PM
mikec0777
Silverado & Fullsize Pick-ups
September 13th, 2009 7:10 PM
