S-10 & Blazer 1982-2005
Upper control arm bushing replacement 1994 S10?
Old April 16th, 2010, 8:33 PM
#1DEER1I's Avatar
Default Upper control arm bushing replacement 1994 S10?
I just have a question on how to replace a 1994 S10 upper control arm bushing. I got the rubber piece out but how do you remove the metal piece of the old bushing, and install the new one? Any help would be appreciated.
Old April 16th, 2010, 10:05 PM
Professional Mechanic
MDTAHOE's Avatar
In the shop we use a air chisel. You can use a hammer and chisel.
Old April 16th, 2010, 10:10 PM
#1DEER1I's Avatar
So you just bust it out? I have an air powered chisel, how do you get the new one in as solid as the old one?
Old April 16th, 2010, 10:39 PM
old dog's Avatar
Default bushing
cut the old one out carefully with the air chisel ,its best to use a press or arbor press but if your careful with the right sized adaptors you can drive them in clean the hole's out first of rust .drive one in insert the shaft in it and then drive in the other one .
Old April 16th, 2010, 10:55 PM
#1DEER1I's Avatar
I'm not sure where talking the same thing old dog, the bushing is a one piece part. Here's a photo of the new bushing I have:
http://www.moogbushings.com/images/moog/L/K6333.jpg
Off the old one I have gotten the middle part out of it (the rubber part) but the outer casing of the old one (just like the one in the photo) is set in place, and that's the part I can't get out, so just chisel it?
Old April 16th, 2010, 11:04 PM
old dog's Avatar
Default bushing
yes the bushing is comprised of three pieces pressed together when they make the bushing ,the outer steel shell the rubber inner and the steel inner that the shaft goes through .
Old April 17th, 2010, 12:07 AM
#1DEER1I's Avatar
So how hard should the old outer steel shell be to remove, as I said I've removed the rubber and the inner steel piece but need to remove the old shell to be able to get the new one in.
Old April 17th, 2010, 7:48 AM
old dog's Avatar
Default bushing
well you have to cut it out it wont be fun but it's doable just take your time and miss your finger's and hand's when swinging the hammer !
jabba66
Silverado & Fullsize Pick-ups
January 16th, 2014 2:39 PM
00chevy1500
November 24th, 2013 10:03 AM
mibar
August 8th, 2013 9:38 PM
jljbtm
November 13th, 2011 7:11 AM
cjm599
June 21st, 2009 7:55 AM
Quick Reply: Upper control arm bushing replacement 1994 S10?
