S-10 & Blazer 1982-2005
Removing cooling fan on 82 s-10
Old July 7th, 2010, 10:13 PM
djmnm310's Avatar
Default Removing cooling fan on 82 s-10
i have a 82 s-10 truck... just need to know how to remove the freakin cooling fan...
Old July 7th, 2010, 10:29 PM
old dog's Avatar
Default fan
i assume you are talking about the fan blade and clutch assembly on the water pump ?
Old July 8th, 2010, 10:06 AM
djmnm310's Avatar
correct.. the fan blade .. im guessing the water pump is bad . . the fan blade is really lose..
Old July 8th, 2010, 10:17 AM
old dog's Avatar
Default loose
don't know what engine but check it real close wear the wobble is those fan clutches go bad on a regular basis .there are nuts on studs that hold the fan clutch to the water pump ( after removing the belt ) .the fan blade and clutch assembly then will come off,You might have to remove the top of the fan shield from the radiator to get the fan out .
soundguy925
April 19th, 2007 2:52 PM
jbronc88
March 22nd, 2007 11:14 AM
ottawaventure
August 13th, 2006 12:26 AM
ottawaventure
August 10th, 2006 9:56 AM
xswinnyx
May 13th, 2006 1:01 PM
Quick Reply: Removing cooling fan on 82 s-10
