Remove door trim on S10 98
The crank handle is held on by a clip that is located behind the crank were it enters the door. There is a inexpensive tool available for removing that clip. When you reassemble the door. Put the clip back in position on the crank and push the crank back onto shaft and it will snap into place.
I do not recall the specific name of the tool. I know I purchased mine at an Advance Auto Parts store and It was made by Autocraft. If you go to your favorite auto parts store they should be able to help you out. I generally refer to it as a window crank handle removal tool.
