Uplander 2005-2009
Platform: U-Body
Noise when going over bumps
Old Sep 6, 2008 | 7:55 AM
  #11
stursu's Avatar
Default RE: Noise when going over bumps
Had same problem see my thread STURSU 9-6-2008
Old Jan 2, 2009 | 11:21 AM
  #12
wolfman75's Avatar
I had the same problem with my 2007 uplander and had it fixed with no problem. before spending all the money on needless repairs check the e-brake cable. Mine had come loose and was clunking the undercarriage when i went over a bunp at almost any speed.
Old Jun 19, 2012 | 8:16 AM
  #13
Tim Andrew Polnasek's Avatar
i think im having the same problem with my 04 chevy 2500hd when i go ofer bumps the front makes a weird knocking noise and the steering goes out for a second or two. what can i do?
Old Jul 8, 2014 | 10:34 PM
  #14
ljdoughty's Avatar
Default clanking in rear-uplander
whenever I go over a bump, there is a metallic CLANK coming from the back, any ideas?
Old Jul 9, 2014 | 3:41 PM
  #15
Official GM Rep
Hey ljdoughty! The metallic CLANK could be from a number of things. Have you taken your dealership technician on a test drive with you yet? That may help in determining the cause of the clanking noise. Let us know if this is something you plan to do. We're here to offer additional assistance if required.
Amber N.
Chevrolet Customer Care
Old Jul 11, 2014 | 10:59 PM
  #16
sledge.impy's Avatar
Yes, check for something loose.. maybe exhaust related.
Old Jul 12, 2014 | 11:50 AM
  #17
When strut bearings go out they can make clunking sounds... also sway bar bushings, shock bushings...
Worn out shocks can allow the body to rest too low causing clunking....
Old May 6, 2016 | 8:31 PM
  #18
Cody Collins's Avatar
Originally Posted by waybro
I have a 2007 2500 HD with 17K miles. About a month ago it started making a Knock orrattling noise andcannot quite make up my mind if it is in the front or rear of the truck.When you drive over a bump it sounds just like someone hitting the under carriage with a hammer. Yep, it just drives me crazy and I've spent more than a couple hours checking for loose boltsor other components under the truck. Cannot feel anything in the steering wheel when it happens.
me too exact same problem I'm having I can't figure it out no loose bolts are no open mind not four-wheel-drive but it makes me just want to strangle somebody
Old May 7, 2016 | 7:22 PM
  #19
Patriot's Avatar
Try to look your rear damper rubber attached to your parking brake...i was also crazy looking for the sound when i go to humps and hear this noise...This is what i found when this happened to me. Hope this helps..
Hiwayman92
21
May 6, 2016 8:22 PM
blackburb_PDX
Jun 10, 2015 10:13 AM
d.lebherz84
Dec 15, 2011 6:16 PM
hobojobo
Jun 27, 2010 2:50 PM
