Should my rotors look like this?
Old Nov 4, 2009 | 4:38 PM
  #11
Flyfishtrip's Avatar
Thanks for the help. I'll take it on Mon and see what they'll do. Hopefully I won't be regretting my first GM purchase. I'll post the results.
Old Feb 24, 2014 | 2:24 AM
  #12
SeattleAl's Avatar
Shawn, don't know if you're still around, but what rotors would you put on a 2004 Burb LT 4wd? Thanks!
Originally Posted by shawnvw
Its not an issue with the pads, its all the cheap recycled steel that comes from china that goes into the rotors. A classic example of why you should get premium rotors when doing brake service. The cheap ones will do, but the rotors won't lastas long as a set of pads
Old Feb 24, 2014 | 9:14 AM
  #13
trainwreck91's Avatar
Don't know if Shawn is still around but Brembo, Baer, Hawk,EBC, Raybestos are all very good brands. A few others I can't think of but any of those companies are top notch and stand behind their products.
Old Feb 24, 2014 | 9:23 AM
  #14
If you are just now replacing your original ones, I would suggest going back with the OEM AC/Delco ones as they will give you at least the same amount of reliability and wear
Old Feb 24, 2014 | 1:54 PM
  #15
SeattleAl's Avatar
Thanks for the suggestions. I just bought the car used with 103,000 miles on it, so I don't really know if these are the original rotors. I don't need high end parts, but I've learned not to go cheap and have problems later.
Old Feb 24, 2014 | 4:07 PM
  #16
You're right about not needing high end and also about going cheap. I always like OEM unless its cheap Chinese stuff they used. But the brands I mentioned are all just as good and they each have they're version of good better and best.
Old Feb 24, 2014 | 7:31 PM
  #17
I use cheap brake parts...but I clean and service my brakes yearly so don't have problems. My vehicle also doesn't sit for long periods.
Chevrolet Forum News
Nov 1, 2012 6:38 AM
SabrToothSqrl
Jun 29, 2010 7:23 AM
tom5170
12
Mar 17, 2010 9:37 AM
HP15
Oct 27, 2006 1:10 AM
