Venture 1997-2005
Platform: U-Body
Other GM rims compatible with Venture?
Old Oct 30, 2007 | 3:06 PM
throne7's Avatar
Default Other GM rims compatible with Venture?
I am trying to get a aset of rims for winter tires. I saw a set of another GM vehicle (91 Buick Regal) rim with teh bolt pattern 5x115 (70.3Bolt hole) 15x6" and other numbers are the same. The only difference is the offset, its shows as ETC: H ie. 45 on teh discountedwheelwarehouse website. http://www.discountedwheelwarehouse...._Reference.cfm
Do you think this will work on a 1999 Chevy Venture? I think the venture has a 0 offset.
REGAL SPECS
OE size: 15x6
Bolt: 5x115
Lug Nut: 12mmx1.5
CB:70.3
ETC: H
VENTURE SPECS
OE size: 15x6
Bolt: 5x115
Lug Nut: 12mmx1.5
CB:70.3
ETC: (empty field)
The only field different is teh ETC field, its empty for the
venture. I read this off the discountedwheelwarehouse wite. I
wonder if the rims are the same. Can someone please help. Can I use
it on my venture?
PastorK
Feb 13, 2010 8:06 PM
CptDondo
Aug 12, 2009 10:59 AM
dmetcalf
Jun 18, 2009 3:35 PM
Derek2023
Oct 17, 2007 7:29 PM
joel davis
Sep 20, 2005 3:46 PM
