I have an 03 Tahoe. The rear heat only blows cold air. I've read about an actuator that can be replaced. Does anyone know the approximate cost if I do it myself? Is there a way I can manually set it to stay on for heat and just adjust the air volume? A part number would be helpful if anyone has done it.
Thanks, Mike
Mike,
Go to www.gmpartsdirect.com. click on catalog, and then open the alternate catalog. Put in your vehicle information and then follow the trail through the air conditioner & heater, Aux, AC and heater unit, to the actuator. Click on temperature valve and then click on the "view illustration". This will show you the exploded view of the aux unit, and you can see the actuator. Costs are there too. Good luck.
Wow. Just did it today.Available on EBAY for about $30-50. The OEM part number is604100.
Pull off right rear panel covering wheel well by taking plastic screw andcargo net knob off. Theres another screw towards the passenger door that needs to come off. If you have the bose speaker that will come off as well, and so will the cigarette lighter power wires so be careful when you pull it. There are three silver screwa that hold the actuator and a power wire. Disconnect them all and then replace. This is the second one for me, the last time, the dealer charged me $240.00.....Good luck
Word of caution, when using www.gmpartsdirect.combe careful not to trust their online catalog. I entered in all my vehicle's info and was directed to a part which I ordered. Turns out it was not the correct part and they don't take returns.Fine print says to verify the part with them prior to ordering. Hard to tell if it's the wrong part until you have it in your hand to compare the numbers.They don't offer part number on their online catalog. They don't claim any responsibility for the use of thier catalog. Kind of a loose excuse if you ask me.
My tahoe has the auto functions for the rear. The part numbers are the same for the two actuators so I swapped to them to verify the fix and now neither one works. When the climate control is turned on it moves all the way in one direction and will not go back. Does it matter what position it is in when it is put in?
I ended up taking the actuator apart and setting it so that it blows hot and put it back on disconnected.
Brental-I just left mine completely off until I get replacements. You can move the small stub that fits into the actuator and it will stay in that position. I have mine set on heat with the air coming out of the roof. I tried to switch mine to see which one was not working too. Now neither one of mine work either. They must be touchy.
Hi, I've got the same problem 03 tahoe. Blower and mode selector works from both controls. Got an after market part (After two tries as catalog list wrong part #), but new temp door actuator still doesn't work. I've verified the temperature sensors both work and the wiring from the actuator to the controller is good. Any other ideas? Can the controller be partially bad? I've also disasembeld both actuators and reassembled, seemed like the controller power needed to be cut to "reset" the actuators, the mode actuator wroked after rebuild, but not the temp door and they did not seem like they wanted to be switched from one place to the next.
