4L60 Transmission
Old Dec 11, 2007 | 11:57 AM
Scantran's Avatar
Default 4L60 Transmission
Hi all, I am re-building a 4L60 transmission. I have up-graded the 3-4 clutch with exra thinner steel and extra friction plates. However, in the re-build manual, the following is stated:
"ATSG recommends that you remove and discard the 3-4 load release spring assemblies, all models, for a much improved 2-3 shift and better 3-4 clutch durability.
"The number 44 hole in the spacer plate must be drilled out to .09" at the same time, even if the hole is not there"
However, in a leaflet sent with the transmission kit (Transgo leaflet), it sates that:
"3-4 Clutch Durability, 3-4 Return Springs. 87up 700's and all 4L60E's NEED these return spings. These springs should always be used with the original thickness bottom and top pressure plate and snap ring".
As I have fitted the 3-4 powerpack which uses additional friction and thinner steel plates, do I need to re-fit the "Clutch Durability Return Springs"?
Could anyone answer the above? All answers appreciated.
Regards
Keith
racerx55
Feb 14, 2016 7:24 AM
shemesh
Jan 20, 2014 4:01 PM
Bbell
11
Apr 14, 2013 12:37 AM
AlwaysChevy
10
Jan 16, 2011 6:55 PM
ArtisanWorks
Oct 27, 2007 5:16 PM
