K2 LED Tail Light Problem
Old Feb 1, 2008 | 2:59 PM
K2Tahoe's Avatar
Default K2 LED Tail Light Problem
Well, after waiting 2 weeks my K2 LED tails finally arrived. I popped the first one in... it was pretty straight forward given no directions were provided. Tested it out and blew a fuse. New fuse and blew again. Any ideas? Tried the other tail and did the same thing. I didn't add a second resistor as others have. Waited on hold with K2 for 30 minutes last night before finally hanging up..
Nothing is ever easy....
Old Feb 1, 2008 | 3:44 PM
laredotexas's Avatar
Default RE: K2 LED Tail Light Problem
hello...
I got the same lights.. make sure that when you plug them the negative from the tail lights plug faces the same black negative from the truck harness.. also before you plug them on make sure that all your lights are off.. i made the same mistake.. follow the same thing with all four plugs.. start from top to bottom... even the small 194 bulb can blow your fuse.. so make sure.. that the black wire from each side of the plug meet when been plug.. on the load resistors.. connect them to the middle bulb only the top one has its own load resistor.
Hope it helps.. let us know.. the out come.. also how did they fit.. on mine i had to cut a peace to make the flush with the truck side panels..
K2's Customer Service Suck.. try contacting Keren from their HR team.. you might find her email on others Negative feedback screan... Another memeber of the Tahoeforum bought a pairand recieved the wrong ones.. he is now waiting to get a new set.. after 3 weeks or so..
Good Luck.. if you need help please feel free to email me.. i have fix most the problems that I encounter with this lights.
LT
Old Feb 2, 2008 | 10:54 AM
did you fix the problem?
Old Feb 2, 2008 | 10:15 PM
hmm.. K2Tahoe?? what sup man.. you got kill installing your lights?? j/k let us know if you where avail to installed them properly.
Old Feb 2, 2008 | 11:07 PM
Slammed's Avatar
There is a big thread on this problem over at the tahoe forum http://www.tahoeforum.com/showthread.php?t=3675
Old Feb 3, 2008 | 1:15 AM
Yea.. go out there.. i started that one.. and you can find alote of info..
Old Feb 3, 2008 | 10:21 PM
K2Tahoe's Avatar
My lights were at my office all weekend.I'll try again tomorrow following your instructions. Thanks!
Old Feb 4, 2008 | 12:38 PM
K2Tahoe's Avatar
Works!! Thanks Laredo!! Just waiting on resistors for the turns..
Old Feb 4, 2008 | 7:46 PM
Nice.. post some pics.. did you had any type of fitment issues?
Old Feb 4, 2008 | 10:31 PM
I think I'll wait 'til jazejeff gets the new build in. This K2 Motors outfit just sounds too shaky.
