Uplander 2005-2009
Platform: U-Body
Noise when going over bumps
Old Feb 7, 2008 | 5:04 PM
allenford's Avatar
Default Noise when going over bumps
My 2006 uplander had so many problems since I got it.
Seatbelt of rear replaced, stablibility and traction control light on, steering rubbing.
Now, when I go over small bumps under a low speed, a noise like something loose heard from front end, and the steering is a little bit sensitive. Went to dealership, two intermediate shaft replaced, and the noise still there, they said they are going to replace the steering column unit, but not sure for it.
Anybody here had same problem?
Thanks for any info.
Old Feb 21, 2008 | 8:06 PM
ktm521's Avatar
Default RE: Noise when going over bumps
Tell them to leave the steering column alone and replace the sway bar links, they should of figured that out its common.
Old Feb 27, 2008 | 5:49 PM
allenford's Avatar
thanks for the reply.
Going to dealer tomorrow, and hope this time is final.
Old Apr 23, 2008 | 3:32 PM
allenford's Avatar
got the whole steering column replaced, and now the noise back again!
Old Jun 2, 2008 | 9:49 AM
RoadWarrior's Avatar
I had a similar problem, but luckily it went away when they replaced an intermediate shaft.
Old Jun 2, 2008 | 3:07 PM
allenford's Avatar
Three intermidiate shafts, two steering columns, one rack were replaced, just within 17 k kms.
and, the noise is still there.
This noise has been driving me mad.
Old Jun 25, 2008 | 2:47 PM
waybro's Avatar
I have a 2007 2500 HD with 17K miles. About a month ago it started making a Knock orrattling noise andcannot quite make up my mind if it is in the front or rear of the truck.When you drive over a bump it sounds just like someone hitting the under carriage with a hammer. Yep, it just drives me crazy and I've spent more than a couple hours checking for loose boltsor other components under the truck. Cannot feel anything in the steering wheel when it happens.
Old Jun 25, 2008 | 8:35 PM
ORIGINAL: waybro
If your looking for an answer to your problem you may have more luck posting in the appropriate section
Old Jun 26, 2008 | 7:39 AM
waybro's Avatar
Thanks for the suggestion. I was just going by the original post "Noise when going over bumps" What would be a good section?
Old Jul 18, 2008 | 5:44 PM
Kenny_O's Avatar
I agree with ktm521on this one. We have 6 Uplanders at work and they all made noise going over bumps.
They all had to have the sway bars worked on in the first year at about 20,000-25,000.
I would take it back and have the dealer look in to the sway bar's
