1999 K1500 Suburban Gas Gauge Oscillating
Old Feb 10, 2008 | 7:51 PM
ts18997's Avatar
Default 1999 K1500 Suburban Gas Gauge Oscillating
I replaced my fuel pump last March. Have had no issues with it since then and the problem I had back then was corrected. Starting about two weeks ago, noticed the needle on the gauge oscillating very fast. The needle will jump around way more than it used to and it is moving in place so fast that it actually looks blurry. It is keeping accurate level of what fuel is left in the tank. When the vehicle is turned on, the needle slams all the way to the right and they goes into the oscillating mode. Does this sound like the gauge itself or the sending unit which is on the fuel pump I recently replaced? Grounding issue? Thanks.
Old Feb 12, 2008 | 10:51 PM
jim71's Avatar
Default RE: 1999 K1500 Suburban Gas Gauge Oscillating
i have same vehicle with same problem before and after replacing fuel pump, would also love to know answer.
Old Feb 28, 2008 | 6:43 PM
aztecf's Avatar
Ditto
Old Nov 12, 2009 | 4:18 PM
Tenmore's Avatar
ditto mine just started did you resolve the problem
Old Oct 20, 2011 | 2:03 PM
Greg B's Avatar
Mine too. Ever since I had the dealership put in a new fuel pump.
Old Oct 22, 2011 | 9:34 AM
photonguru's Avatar
Default Fuel gauge oscillation
Change the i/p cluster. I found a good used one on ebay. Swaps out in ten minutes. Resolved the problem which, strangely, correlated with replacement of in-tank pump assembly. Checks of ground wire, connectors, even a different vendor in-tank pump / sender assembly [Bosch] did not yield any improvement. I did not dig further into the i/p cluster to identify if the gauge itself was at fault or some other component in the cluster such as regulator or printed circuit foils. Hope this helps!
Old Oct 22, 2011 | 3:34 PM
legolas894's Avatar
Ditto Ditto. Haven't tried the I/P switch. I see them on ebay all the time.
Old Oct 25, 2011 | 3:13 PM
Michael Smith's Avatar
New guy question: What is an "I/P switch"? I have a 1999 suburban with the same issue...
Old Oct 26, 2011 | 6:28 PM
legolas894's Avatar
That would be switching out the old I/P for another one. Sorry...
Old Oct 26, 2011 | 7:51 PM
the ipc most likely has circuitry that buffers the fuel level signal so that it doesn't react to every minute movement of the fuel in the tank.
