Platform: Delta
Also Check out CobaltSS.net
06 cobalt ls. accessories not working
Old Feb 12, 2008 | 2:37 PM
Friggen_Cobalt's Avatar
Default 06 cobalt ls. accessories not working
well I salvaged an 06 cobalt atx. Got it all put togeather and running. Runs smooth... except it has no power steering, no a/c, no windshield wipers, and no rear defrost. Also the DIC doesn't work properly and only cycles between "service air bag"(bad passenger seat sensor) and "change oil soon"(can't reset). I can't cycle through it manually. Still shows the mileage when the door's open and the car's off.
The blower motorworks,but I can't change the temp or volume of air that comes out of the vents. a/c button and rear defrost button does not light up or come on. But the radio works.
Car has no power windows or locks.
No communication at all to my MODIS
Tested the bcm. Getting no voltage out ofmost of the fuses. A couple of millivolts at best. I figure I should replace it as that's what's causing the problem, but I'm also getting a light on the dash on startup that looks like it could be an anti-theft light or something. I'm wondering if it could have something to do with everything that's going on. I know some anti-theft systems tend to shut down certain vehicle functions when activated.
If anyone has an idea what I should do any info is appreciated. Thank you
Old Feb 13, 2008 | 5:36 PM
Default RE: 06 cobalt ls. accessories not working
anyone?
[/align]
Old Feb 18, 2008 | 10:41 AM
charlie pachanga's Avatar
blown fuse at engine fuse panel seems to be 2 amp fuse. check allyour fuses in the engine compartment.
tbehman@gmail.com
Cobalt
Apr 13, 2011 11:21 AM
jlenkows
Jan 10, 2007 2:01 AM
TypeR0149
Oct 12, 2006 12:06 AM
slikkkk2005
Aug 29, 2006 2:57 AM
BABY_21
Dec 8, 2005 10:39 PM
