Platform: Delta
Also Check out CobaltSS.net
Aftermarket cruise control module - thoughts?
Old Feb 24, 2008 | 4:09 PM
jerimiahy16's Avatar
Default Aftermarket cruise control module - thoughts?
I found this small cruise module that is mounted to the dash via double sided tape. 160 bucks. All looks good on the reviews and all but can you guys share your oppinions and you think it'll work on my cobalt 07?
http://www.jcwhitney.com/autoparts/P...000566/c-10101
Old Feb 25, 2008 | 3:17 PM
Default RE: Aftermarket cruise control module - thoughts?
that module will not work. It uses a module under the hood to pull the throttle open. Your car has an electronic throttle control.
check this module out....its close to the same price and looks much better. It uses an RF switch so you can mount it to the steering wheel without running wires.
The only downfall is having to get it programmed at the dealer. It ony takes about 10 mins to program it so it shouldn't be much.
Old Feb 25, 2008 | 3:33 PM
ORIGINAL: shawnvw
I had a feeling it wouldn't work. Thanks.
Now which one are you talking about? There was no link.
Old Feb 27, 2008 | 7:44 PM
sorry bout that
http://www.oem-auto-accessory.com/ro...lete_kit_.html
pjm333
Aug 19, 2015 3:40 PM
pcwilcox
Oct 21, 2013 11:00 AM
liljoe66
Aug 5, 2011 12:44 PM
tkdunn
Jun 20, 2010 11:15 PM
kbridge234
Sep 4, 2008 10:03 AM
