S-10 & Blazer 1982-2005
Hello....Im new here
Old May 16, 2006 | 10:48 PM
MyChivvy's Avatar
Default Hello....Im new here
Hello, my name is Amanda, I just recently picked up an 85 s10 with a 1.9L for 500 bucks. So far the only problems I have come acrossed is an exhaust leak. Has anyone else come across any problems with this particular year??
Amanda
Old May 16, 2006 | 11:03 PM
Nomad76lj's Avatar
Default RE: Hello....Im new here
hello and welcome to the site. these trucks are prety tuff. if you have any problems just post and im sure someone will have the anser.
Old May 17, 2006 | 12:16 PM
MyChivvy's Avatar
Well, thanks and the only thing that I have really noticed that I think may be wrong with it, is that the clutch "chirps" but only when I don't have it in. Well, that and the window washer fluid sprayers dont work, but eh, thats not a big deal at all. Don't reallhy care about that. The clutch chirping however, is a little bothersome, because, I don't know anything about clutches. Any help on this issue would be great.
Amanda
Old May 17, 2006 | 1:38 PM
Nomad76lj's Avatar
it may need to be ajusted a bit but its not a big deal right now as long as it shifts smothly. the window washer thing is an easy fix to. the motor is i=on the washer botle. just pull it out and put a new one in.
Old Jul 3, 2006 | 10:58 PM
kcb37's Avatar
Do you have a fluid resivor for the clutch. It will be by the brake fluid,(should be on the firewall) If you do you have a hydralic clutch. I don't know when they started in s10's but they cannont be adjusted. The chirp could be you giving to much clutch, and spining the tires, it could be a throw out bearing, or a piolt bearing. Kinda hard to tell without hearing it. Keep an eye on the ball joints, lower especially, I haven't had to much of a problem,(replaced mine) but I have heard they go bad on these.
Old Jul 9, 2006 | 1:49 AM
MyChivvy's Avatar
Well, yes I do have a clutch reservoir. haha, my tires don't squeal. My truck has a 1.9L witha sbbl carb. Nothing special. I just roll it, I don't care enough about it to put money into it.
Old Jul 11, 2006 | 10:40 PM
kcb37's Avatar
You might be suprised what you can do with a clutch. It all depends on how you drive it.
Old Jul 12, 2006 | 11:30 AM
MyChivvy's Avatar
Well, its got 100,000 miles on it, I dont beat on it at all (to afraid to). I have never heard the tires squeal, and the chirping noise, is inside my truck. Im not to sure what it is, the clutch also vibrates too. I think I need a new clutch?
Old Jul 13, 2006 | 3:09 AM
kcb37's Avatar
You may also need to get your flywheel turned. That's the same as turning a brake drum or rotor. It just shaves it down until it's a smooth surface again.
red888
Mar 31, 2010 3:35 AM
Nicegirl
Mar 6, 2009 10:26 AM
gearmonkey
Jun 17, 2008 10:33 PM
Stealthrtsc
Dec 4, 2006 9:21 PM
cumadogg
Oct 24, 2006 1:00 AM
