yah i will put up those links, mine is made out of plastic, if you use pvc pipe you can have a tube on the side that connects at the top and bottom to show the water level, when you have a system setup too you should have another container that the hydrogen goes into and bubbles in, this helps prevent flashbacks and cleans the gas, im still searching thou for a good container to use
if you have a cold air intake you just tap into to side of that, i would not hook it up directly to a vacuum line cause my buddy did that and it sucked in water lol
yeah i made a system that works quite well, i havent really hooked it up thou, i want to make something better i just havent gone looking for a good container, i want a clear plastic container, still trying to find a good one
thats cool i might buy some plans one day too, spend pics please of your unit when your done,
here is an air induction system, not a fan of the name but whatever, there are other ones simular but i think this is the best one and its only 40 bucks http://www.turbonator.com/
this is the best on line fuel seperator 160 bucks i think http://www.fuelconcepts.com/?gclid=C...FSrNiQodKRPWcw
my system makes so much hydrogen that container starts leaking so i need something that seals better, a clear one would be the way to go
