S-10 & Blazer 1982-2005
1995 s-10 p/u stalling problem
Old Mar 14, 2008 | 11:00 PM
radarglove's Avatar
Default 1995 s-10 p/u stalling problem
i am having a stalling problem with my 1995 s-10 p/u
truck will run for about 5 min. then engine will die.
thought it was a fuel pump problem so had it replaced
but when running it today the same thing happened.
this time it was while i was driving. truck just quit running and
had to pull to the side of the road. check guage light did come on
as well as the battery logo light. let sit for about 5min. and it
started back up but only ran for a short distance before stalling
again. any help would be appreciated
Old Mar 16, 2008 | 10:54 PM
kenehsr's Avatar
Default RE: 1995 s-10 p/u stalling problem
Did you replace the fuel filter when you replaced the fuel pump? Check to make sure your getting spark.
Old Mar 17, 2008 | 7:01 PM
have you checked the charging system?
Old Apr 25, 2009 | 5:56 PM
rio9760's Avatar
Did you find the problem with the truck? I'm having the same problem my s10 pu is a 92, it runs good then stalls, restart and have to feather the gas pedal to keep it running? Changed the fuel filter and did a complete tune up <no good> still have the problem? Any suggestions? TU
Old Sep 19, 2009 | 11:48 AM
amond75's Avatar
I have a 94 and it did it to me, ended up being the ignition moduel. Also may wat to check out the crankshaft position sensor
Old Sep 19, 2009 | 6:01 PM
tm4hammer's Avatar
Change the filter then check fuel pressure with a gauge and fuel pump relay i have installed a few pumps that were defective right out of the box
Old Jan 15, 2011 | 10:56 AM
punshka's Avatar
Default 95 Blazer Stalling Issue
We are having the same problem you guys are having. We haven't figured out what is causing this, though!!!! We are hoping that because we have a bad cam and 2 bad lifters, by us replacing them, it fixes the whole problem. How can you tell if your crankshaft sensor is bad or not? Also, if the sensor is bad, would that cause the truck to work fine and then a couple of miles later, stall out? We don't have any problem cranking it back up, once it has stalled out. Let me know what you think. Thanks.
Old Jan 15, 2011 | 7:55 PM
lynnboy021's Avatar
if its bad you wont get spark at all if its so so then sometimes u will get spark and sometimes not.
Old Feb 19, 2011 | 7:58 PM
devriesj39's Avatar
i have been having the same problem in 94. replaced the fuel pump and filter but did not help. so where is the crankshaft position sensor located on these. thanks
Old Mar 24, 2011 | 10:49 PM
amond75's Avatar
Mine did that till I checked the voltage to the fuel pump relay. replaced, and it cured my problem
Bh3zfc
Jul 21, 2015 6:28 AM
jrobpush
Mar 22, 2013 10:37 AM
cwl
Nov 30, 2012 9:23 PM
Scantran
Apr 16, 2011 2:54 PM
natemclain
Aug 4, 2009 10:46 PM
