Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Chevy Trucks, SUV's, & Crossovers > S-10 & Blazer
Old 03-17-2008, 11:29 PM
rteas48183 rteas48183 is offline
Default 1995 Chevy s-10 4.3 vortec runs rough at idle loss of power under load
Rough idle loss of power under load [/align][hr]
GA_googleFillSlot("Forums_ROS_300x250_noad");
var tcdacmd="sa=a;sz=3;ad";
[/align]
I have a 1995 Chevy S-10 4.3 liter vortec 2wd automatic TBI, vin code "Z" 215K miles, running rough at idle, but has a steady purr while being held at 2500 rpm in park, put it in drive and stomp the pedal it falls on its face sputtering, spitting, an occasional backfire, a nice rich gas smell out of the exhaust. Cannot hold any speeds steadily on the road. The RPM gauge goes irattic and jumps up and down, occasionally returning to normal, Had not thrown any codes / check engine lights. Untill i replaced the EGR valve which i was convinced after speaking with many people (some mechanics) went through 3 EGR valves before getting the right one (thank you delphi), she ran at idle decent for 15 or so mins. then the check engine light came on. so i went to have it scanned and the ODB II kept telling me link error, so another scanner was used with the same results. This truck has new Ac Delco, plugs, wires, cap, and rotor within the last oil change, The light goes off and on now, with no real difference in the way it runs. Any help would be much apprieciated. If i can't resolve this problem The truck will be sold dirt cheap i have 2 much money sitting in a truck that is not road worthy, and watching the rust come out pisses me off. Rteas48183@comcast.net[/align]
Old 03-18-2008, 02:37 PM
dragonrpc's Avatar
dragonrpc dragonrpc is offline
Default RE: 1995 Chevy s-10 4.3 vortec runs rough at idle loss of power under load
Sounds like you tried the basics EGR/plugs, tune-up etc...
Next I would,
Check fuel filter, then fuel pump, then injectors if applicable.
__________________
2007 Mercedes ML63 /AMG
Sold 1999 Chevy S10 4X4 Blazer - 7" Trailmaster lift - 4.3
Sold 1994 Chevy S10 4X4 Extra Cab Pickup - 4.3
Sold 1967 Chevy Camero - 327
Old 03-18-2008, 05:59 PM
Ride of the Month
April 2009
2000 Chevrolet Blazer
My Garage
Your timing is off. Classic symptoms of timing. Try to adjust it back to a range of -2 to 2 degrees.
Tags
1995 , 43 , 94 , 95 , blazer , chevrolet , chevy , drive , idle , idling , loss , marker , park , power , rough , s10 , timing , vortec
HTML code is On
