K5 Blazer 1969-1994
Platform: Truck, GMT 400
parking brake light
Old Apr 12, 2008 | 11:54 PM
joe130man's Avatar
Default parking brake light
my 92 parking brake lightin the dashcomes on when i press thebrake pedal down about half way. but if i pump the brake once before pressing the pedal all the way downthe light will not come on. and ifthe light ison and i pump the brakes it goes off.
I have checked the fluid and it isfull
does any know wat the problem mite be?
i can also feel something in the pedal when the light either goes on or off
Old Apr 13, 2008 | 7:33 AM
Default RE: parking brake light
you either have some air in the lines, or a bad master cylinder. If you haven' done any recent work, then i would say its a bad master. The bore is more than likely a bit corroded allowing fluid to leak passed the O-rings.
Old Apr 27, 2008 | 7:33 PM
austin408's Avatar
yea, mine does that to.. but i havent try'd pumping my brakes.
ill check out my master, but i would like to upgrade my brakes to rear disks also..
anyone know a good conversion kit???
it probably will require a different master, i dunno..
4WD Korea
Jan 12, 2020 11:35 AM
kaptain howdie
Dec 16, 2014 8:20 PM
plush17
Jun 25, 2014 11:00 AM
ubique
Mar 26, 2008 9:45 PM
