2003 suburban Z71 speedometer not working
Old Apr 18, 2008 | 3:49 PM
lenny_wakefield's Avatar
Default 2003 suburban Z71 speedometer not working
I have 2003 Z71 suburban and the speedometer will not read properly. 90% of the driving time its at 0 mph and the other 10% it reads any where from 5 mph to 120+mph. Any info would help.
Old Apr 19, 2008 | 7:13 PM
03blackburb's Avatar
Default RE: 2003 suburban Z71 speedometer not working
Your speedo stepping motors are bad. GM has a notice on these and yours may be covered, they have an extended coverage for the 03's. Check you your dealer. If it is not covered, check ebay. You might be able to upgrade to an escalade cluster or just have you existing on rebuild.
Old Aug 7, 2009 | 9:54 PM
chevyp2p's Avatar
Thumbs up solution for your cluster problem
I had the same problem with the speedometer in my car. I found a website where I had it fixed for $140. They rebuild the entire cluster the guy said that all the gauges in the instument cluster are driven by the same type of motors and that I should replacce all of them before the were out. It made sence to me since the rpm's gauge was beginning to act weird. anyways here is the addres in case you wanna check it out.
http://www.speedometergaugerepair.com
Merkel3594
Jan 7, 2022 10:33 PM
cory74700
Dec 13, 2019 9:38 AM
Harmsie
Uplander
Jun 2, 2008 9:41 AM
isswd
Feb 13, 2008 5:41 PM
jweiby
Nov 3, 2006 1:39 PM
