Headlight Issues
Old Apr 20, 2008 | 10:35 AM
USMA12's Avatar
Default Headlight Issues
I have a 4dr '97 Tahoe and I have a problem where the driver side headlight is extremely dim and the passenger side is extremely bright. I replaced the bulbs thinking that was the issue, but it did not change anything. I adjusted the headlight to see if it would change anything, but its still dim no matter what angle it is at.
Any ideas? I was thinking maybe its an issue with a relay, but im really not sure.
Thanks
Old Apr 20, 2008 | 1:37 PM
Default RE: Headlight Issues
I have the same problem with my dad's 99 Suburban... but both are extremely dim.
Old Apr 20, 2008 | 9:36 PM
e's Avatar
e
Do you have a volt meter tocheck the differences in voltage between the left and right side?
Also unplug the light and look into the harness. Is it corroded or burnt?
Old Apr 23, 2008 | 10:23 PM
timdogg1313's Avatar
same problem on 97 and it is that the lens cover is dingy. they sell a kit at the auto parts store that is said to really help clean the lens up as you have to go to the stealership to get new lenses. good luck and please post if you find the solution.
Old Apr 24, 2008 | 2:44 PM
Check the ground of the side that is dim. there is probably a bad connection there causing it to back feed throught the other side.
Old Apr 24, 2008 | 3:14 PM
ZX1100F1's Avatar
ORIGINAL: shawnvw
+1.
Old Apr 24, 2008 | 7:29 PM
2007TahoeLTZ4x4's Avatar
how old are the lights themselves? isnt it true that headlights rarely burn out but just get dimmer so maybe get some new ones
garyv990
Feb 11, 2015 9:52 PM
Philthytoo
May 24, 2010 3:06 PM
Lwags
Apr 14, 2010 8:18 PM
tnt82
Jan 15, 2010 11:22 PM
