Astro 1985-2005
Platform: M-Body
93 astro van
Old May 6, 2008 | 4:09 PM
davidfield's Avatar
Default 93 astro van
help my van stops running at stop lights and such and if only if i can get it started It will run for a day just fine the next time i go out to start it nothing..... I have replace fuel pump fuel filter went to auto zone had them run a test to see why check engine light was on they told me it was one of the sensors i had just replaced idel air control also had them check out ignition moduel it was also fine now it will not start any suggestions
Old May 6, 2008 | 7:39 PM
Default RE: 93 astro van
Welcome to the forum! This isn't a tech section, so if you repost your question in the Astro section, you'll get an answer.
Old May 6, 2008 | 7:56 PM
northey87's Avatar
Welcome!!!
Old May 7, 2008 | 7:42 AM
davidfield's Avatar
my 93 astro began randomly stalling at stop lights sometimes restart after few minutes.have replaced fuel pump,filter,plugs,wires,rotor cap,distributor cap,oil pressure sensor,idle air control,fuel pump relay.ran fine about four hours brought home shut it off,back out hour later wont start.
joe200120012001
Aug 22, 2007 7:35 PM
ssn123
Astro
Jan 2, 2007 9:35 PM
Top
Follow Us
