S10 & Blazer DIY and Useful Threads This section is strictly for frequently asked questions pertaining to S10s and Blazers.
Wiring----Color Codes-----
Old May 20, 2008 | 11:17 AM
rabbit0102030's Avatar
Former Moderator
Honorably Retired Member of Staff
Default Wiring----Color Codes-----
82-93 S-10 or blazer
12volts red (there will be 2) + ignition harness
Starter yellow or purple + ignition harness
Ignition pink + ignition harness
Second Ignition white + ignition harness
Accessory orange + ignition harness
Second Accessory brown + ignition harness
Power Lock lt. blue drivers kick panel
Power Unlock black/white drivers kick panel
Parking Lights+ brown switch or rear harness
Door Trigger white - pin or courtesy light
Dome Supervision use door trigger
Trunk/Hatch Release black + relay under left dash
Tachometer white AC coil on top of engine
Brake Wire white + at brake pedal switch
Parking Brake black - at the e-brake
Horn Trigger black - steering column
95-97 blazer or 94-97 S-10
12volts red (there will be 2)+ ignition harness
Starter purple or yellow + ignition harness
Second Ignition white or pink/white + ignition harness
Power Lock lt. blue + either kick panel
Power Unlock white + either kick panel
Lock Motor gray drivers kick panel
Unlock Motor tan drivers kick panel
Door Trigger white - keyless module
Trunk/Hatch Pin tied in with doors
Trunk/Hatch Release black/white + switch or keyless
Tachometer white AC ECM
Parking Brake black at the pedal
98 + S-10 or blazer
12volts red + ignition harness
Starter yellow + ignition harness
Power Lock lt. blue + brown plug at BCM
Power Unlock white + brown plug at BCM
Lock Motor gray 5wi driver kick panel
Unlock Motor tan 5wi driver kick panel
Parking Lights+ brown + lt. blue plug at BCM
Parking Lights- white - lt. blue plug at BCM
Door Trigger - BCM
Trunk/Hatch Pin pink/black - lt. blue plug at BCM
Trunk/Hatch Release black - purple plug at BCM
Tachometer white ac PCM
Brake Wire white + steering column
Parking Brake black - at the pedal
Audio Related (covers all years except for slight variances)
Radio 12v--- orange
Radio Ground--- black
Radio Ignition--- yellow
Radio Illumination--- brown
Dimmer--- gray
Power Antenna--- pink...never in a s10 or blazer...but other gm's
LF Speaker +/- tan - grey
RF Speaker +/- lt green - dk green
LR Speaker +/- brown - yellow
RR Speaker +/- dk. blue- lt. blue
Old May 12, 2009 | 3:58 PM
patioman's Avatar
Cool Ignition Black Wire?
Hey Rabbit,
I also have a black wire coming from the ignition switch for my 82 S10 column. Any idea what this is for? I am putting the column in a 49 Chevy Pickup and am doing the wiring myself.
Thanks...
patioman
Old May 13, 2009 | 10:10 PM
Ground most likely.
Old May 13, 2009 | 10:18 PM
suzuki-guy's Avatar
Yes black usually indicates a ground wire.
Old May 14, 2009 | 7:40 AM
patioman's Avatar
makes sense to me....thanks
Old May 19, 2009 | 2:20 PM
roofah76's Avatar
Default need help 98 s10
hey i have a 98 chevy s-10 i had to take the dashboard out because i snapped the plastic pivot for the clutch pedal anyways everything went smoothly back into place but i have a plug that dosnt have a home i work for a nissan dealership and by no means am i stupid.
the plug is pertruding through where the e-brake release is (i havent put that panel on yet) it has 10GA wire with red blue orange and brown
i tried alldata and mitchell and still nothing
Old Sep 27, 2010 | 4:39 AM
521monpy's Avatar
Lightbulb The Revenge (joke)
Old Farmer Johnson was dying. The family was standing around his bed. With a low voice he said to his wife: "When I'm dead I want you to marry farmer Jones."Wife: "No, I can't marry anyone after you."Johnson: "But I want you to."Wife: "But why?"Johnson: "Jones once cheated me in a horse deal!"No money no way in real life,no gold no way in game!
Old Nov 2, 2010 | 7:58 PM
dbgfreeusa's Avatar
Default '89 S-10 Blazer under-dash wiring photo?
Hello,
I like the post but have not been able to find what I need.
I am in need of a color photo of the wiring harness that includes the various interior lights, ashtray light, glove compartment light and radio wiring for an '89 S-10 Blazer. I've searched online including Autozone's slte and I have not been able to find what I'm looking for.
I disassembled my dash and failed to label which wires go where. It's been long enough that I cannot remember, and to complicate matters the aftermarket stereo does not utilize some of the wiring and plugs that still exist behind the radio.
I think what remains to be put back in their proper places are 2 or 3 courtesy lights, the ashtray light and the glove box light.
If this type of photo is available from a particular manual or book that can be found in a library, etc. I sure would appreciate being aimed in the right direction.
Thanks,
DBG
Old Aug 28, 2014 | 1:44 AM
jamie4jessica53's Avatar
Hey I have a 2012 RG Colorado im tryying to put a turbo timer on but im having trouble with the ignition harness colors can somebody help me? Thanks
Old Jan 4, 2015 | 9:38 AM
wasww's Avatar
Smile wiring colors
If you go to any GM dealers repair shop, they should have a repair manual and they should be willing to give you a photo copy of a page or two.
If you ask and they won't do it, go to another GM dealers shop.
This usually works for me.
