Platform: A-, G-, & W-body
95 lumina master cylinder
Old May 21, 2008 | 8:49 PM
matthew17's Avatar
Default 95 lumina master cylinder
was changing master cylinder on lumina and had to remove black box that was mounted to it i assume it is abs control, it was geared and when i removed it the gears had tension and spun, i should have stopped when i saw that i had to remove the box but didnt, what do i have to do when putting it back on,any help would be appreciated,
Old May 21, 2008 | 9:36 PM
Default RE: 95 lumina master cylinder
get one from the wreckers and replace it as a unit
Old May 27, 2008 | 3:00 PM
a4d's Avatar
a4d
you mean the black thing attached to the master cylinder on the firewall? If so thats a brake booster. I dont think there is a seperate comp for ABS just sensors, and controlled by BCM.
Old Aug 9, 2008 | 1:52 PM
cfrank's Avatar
ORIGINAL: a4d
I dont know what you are reffering to when you say the "BCM" but on every ABS equipped vehicle the abs system has its own computer.
pu70
Astro
Aug 30, 2008 6:58 AM
rjsasaoka
Jun 10, 2008 6:37 PM
new2chevy
11
Apr 25, 2008 3:20 AM
chevy3quarta
Aug 6, 2007 6:34 PM
