K5 Blazer 1969-1994
Platform: Truck, GMT 400
Problem with 700 trans
Old Jun 9, 2008 | 6:48 PM
jasontay's Avatar
Default Problem with 700 trans
Here it goes.....When I coming to a stop it shifts from 1st to 2nd back to1st a couple of times before it comes to a stop ....I replaced the fluid and filter last wekend and made sure I got the old o-rings out this is driving me crazy... please help
Old Jun 9, 2008 | 7:09 PM
Default RE: Problem with 700 trans
sorry, my psychic abilities are broken.....we need a little more info on the vehicle before we attempt to give you advice.
year,make,model,motor,trans,how long has the problem been apparent? Its better if I....? Its worse if I....? no rhyme or reason....happens all the time.....etc etc etc
Old Jun 9, 2008 | 7:35 PM
John Hart's Avatar
...Also....what is its behavior when accelerating from a dead stop?
Old Jun 9, 2008 | 8:45 PM
jasontay's Avatar
87 chevt blazer k5 350 eng.700rt trans. It only happens when going over 30 or so when coming to a stop is when it starts shifting from 1st to 2nd back to 1st and so on a couple of times ,From a dead stop 1st to 2nd is fine 2nd to 3rd takes awhile I usually have to let off the gas for it to change i dont drive it in OD Im only driving about 10 miles round trip to work OD is tp sluggish for me.
Old Jun 10, 2008 | 9:33 AM
John Hart's Avatar
I'm wondering about the Throttle Valve (TV) or TV cable maladjustment. It's pretty sensitive and may give you these exact symptoms.....'specially since you have to let up on the gas to shift to 3rd
lefevre32
Jul 26, 2011 8:05 AM
cmonteiro1
Oct 7, 2008 6:57 PM
1986c10
May 9, 2008 7:51 PM
m0n0x!de
May 8, 2008 1:06 PM
MrSwapIt
Aug 21, 2007 6:54 AM
