K5 Blazer 1969-1994
Platform: Truck, GMT 400
700r4 not shifting out of 2nd
Old Jun 17, 2008 | 10:26 PM
GetYanked's Avatar
Default 700r4 not shifting out of 2nd
It was shifting before I took it off road today now it wont shift out of1st any ideas?
Its is a 87 K5.
Old Jun 18, 2008 | 5:07 AM
John Hart's Avatar
Default RE: 700r4 not shifting out of 2nd
A few things come to mind.
Does it shift out of 2nd into nothing, or does it stay stuck in 2nd?
Depending on the symptom, TV cable broken or maladjusted, low fluid, broken or burned 3-4 clutch plate, something wrong in the valve body.
Old Jun 18, 2008 | 8:42 AM
GetYanked's Avatar
No I edited it. It wont come out of first NO SLIP in first at all but will not shift into 2nd.
Old Jun 18, 2008 | 12:48 PM
John Hart's Avatar
Sounds like a Throttle valve problem....either the cable or valve is stuck open
Old Jun 19, 2008 | 9:03 AM
John Hart's Avatar
Now that the forum is working better, I can explain better. I was thinking that if, while out 4 wheelin', you tromped on the accelerator, and the throttle valve got stuck in the deepest part of it's bore, then you might end up with a transmission that wants to always downshift to 1st gear. Seems that it would be easy enough to check....by tugging on the TV cable at the carburetor, there should be the sensation of a spring loaded valve. If there isn't, thenthat's where the problem is. But then I'm just guessin'.
Old Jun 22, 2008 | 12:01 AM
GetYanked's Avatar
The problem was I went in water over my dipstick tube and the tranny got water in it. I didnt notice cuz I was drivin around if first all day with the water in it. Wehn I got on the road and shifted though the gears it just **** housed itself. I just got it back from the tranny shop this morning it now was a built 700r4 with 3.06 first and a shift kit the t-case was also went through.
darthburban06
Apr 14, 2018 8:49 PM
z064fun
May 13, 2014 7:51 AM
BTiddleybocker
Jun 21, 2008 8:37 AM
ryanmetcalf
Feb 21, 2007 6:26 PM
Summett
Feb 13, 2007 2:59 PM
