Astro 1985-2005
Platform: M-Body
1989 astro van power window problem
Old Aug 7, 2008 | 4:39 PM
mrmark's Avatar
Default 1989 astro van power window problem
hi everyone i cant get my passenger window to come up ive tested power at the motor and have both sides with power on the door switch the drivers door switch only shows power at the motor on the down side i also bought a new motor and its the same problem? this is a conversion van also thanks
Old Aug 8, 2008 | 3:50 PM
mrmark's Avatar
Default RE: 1989 astro van power window problem
man i cant believe no one has had this problem before... any help would be appreciated. thanks
Old Aug 31, 2008 | 8:03 AM
bo's Avatar
bo
I came to this forum for the exact same reason as your post.I had noticed my passenger side power door lock quit working about a week or twoago. The passenger power window button had been hit andsince December 2005 when I first aquired my 1992 Astro. The driver side has always worked so no big deal. Last week my daughter rolled down the pasenger windowusing the passenger side buttton. I thought maybe the button started working again only to later figure out the window was stuck in the down position and would not even operate from the driver side. I have only looked for the obvious so far. I had a similar type condition in a 1989 Nissan Maxima a few years ago and finally learned that I had the replace the master control switch(driver side switch assembly). Not sure if the Astro driver switch is as complicated as the Maxima. The Maxima master switch was electronic. The Astro appears to be amechanical sytle switch. Maybe we can get someone to post a fix to this dilemma. It certainly can't be a unique problem.
P.S. The company I work for has used Astros for years in its fleet. I check with our mechanics to see if they have seen this problem before.
Old Aug 31, 2008 | 10:07 AM
fix the broken wires in the door boot
Old Aug 31, 2008 | 10:19 AM
mrmark's Avatar
ok well i bought a new drivers door master switch and no luck i did take a quick look at the wires in the door boot but i will revisit them and do a better check. thanks and i will let you know when i figure it out
Old Sep 10, 2008 | 3:50 PM
mrmark's Avatar
thanks you hit it right on the head i finnally got a chance to take a look in the door boot and sure enough i had 3 broken wires and the rest were chafed. so i fixed the broken ones and taped up the others and everything works as before..well thats what i get for paying my helper to look at the wires in the boot he told me they were fine he never took the boot off i think because they were plain as day... well thanks again and hope this thread helps others... please close thread
Old Sep 10, 2008 | 5:41 PM
bo's Avatar
bo
Thanks to shawnvw for guiding mrmark and myself to the correct fix. I completely removedthe section of passenger side wiring boot while leaving thetwo reinforced boot ends in place. I found 3 wires broken in two and another cracking. The rest of the wiring felt ok and showed no signs of damage. I spliced the 4 wires back together using a short insulatedcrimp sleeve and my window and door lock problems are gone. THANKS AGAIN SHAWNVW.
[IMG]local://upfiles/19917/5386D42FA09D4BE1AE35C7C77805EE7A.jpg[/IMG]
[IMG]local://upfiles/19917/0116120FC83B47DCB64485377EDAC9D4.jpg[/IMG]
[IMG]local://upfiles/19917/27E90CD20D054F05A36DA7877196659F.jpg[/IMG]
Old Sep 10, 2008 | 7:25 PM
no problem guys
glad to hear you got it fixed up
Old Sep 12, 2009 | 4:46 PM
heavymetl420's Avatar
yes sir all my windows work now thanks
Old Jun 17, 2013 | 12:16 AM
wayup's Avatar
Default 1995 Astro window master switch
Where can I find a 1995 Astro window master switch?
My switch is broken. Will not roll up the passenger window.
