Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Chevy Cars > Malibu
Old 08-30-2008, 05:38 PM
ilovefox ilovefox is offline
Default 2000 Malibu check engine light problem
Hi, I am a new user in this forum. Please help me to have a look at my car check engine light problem.
I bought this 2000 malibu 60k miles from a dealer this month, and the check engine light was on for 3 times. The first time, the dealer invoice said " check codes-P440-large evap. leak code", and they reset the code. After 2 days, the light was on again, the dealer did some work on it and said they replaced some part and reset the code. Then after 2 days, the light was on for the 3rd time. Now I am almost frastrated, I don't know what to do, should I ask the dealer to fix it the 3rd time? I am afraid it will come out the 4th time...
Can someone give me good suggestion? how to fix the code P440 problem? Thank you so much!!!
Old 09-28-2008, 10:34 PM
nicey8 nicey8 is offline
Default RE: 2000 Malibu check engine light problem
even if you didn't purchase an extended warranty you should have you 3/3 warranty.. take it back to the dealer until it it fixed
Old 10-05-2008, 07:16 PM
Diller23 Diller23 is offline
It could be sensors or a fuse tell them to make sure they run through those as well that was the problem with our 2001 blazer when the engine light kept coming on I think it might have been a problem in chevys wiring departments?
__________________
Limiters suck!!!
Old 10-05-2008, 11:19 PM
shawnvw shawnvw is offline
Bring it back to them and have them fix it. If you start messing around with it, it will only give them a reason to not warrant it.
__________________
Old 09-17-2009, 10:55 AM
kuntrybo kuntrybo is offline
Try getting a new gas cap, a faulty gas cap can cause a p0440 code, computer see's it as a vaccum leak. i would suggest an ac delco part
Old 09-17-2009, 01:59 PM
mel902 mel902 is offline
Was the ERG replaced on it? If so i have heard of unhooking it when you erase the codes might fix it.
Old 09-18-2009, 08:59 AM
OnDaGround's Avatar
OnDaGround OnDaGround is offline
Quote:
The seals do not typically go bad. Tighten the gas cap and it should shut off in a couple miles if not after 30 seconds.
__________________
"Tell your boyfriend, if he says he's got beef... that I'm a vegetarian and I ain't F___king scared of him."
1998 Malibu Ls -- Daily Driver. High Quality audio mods only.
1993 Saturn SC2 -- It would surprise you --
CAI, Pacesetter Header, Easterns h/f Cat, PaceSetter CatBack, walbro 255lph racing fuel pump, Apexi SafcII management system,Plx M-300 Wideband Controller, other misc performance mods.... mini 2100lbs road warrior
Old 10-23-2009, 12:40 AM
killaforniaxkrystina killaforniaxkrystina is offline
i found this, hope it helps!
its got symptoms and solutions
it even explains why :]
http://www.obd-codes.com/p0410
Tags
2000 , 2001 , blazer , check , checking , chevy , code , codes , engine , fuse , light , malibu , p440 , reset , resetting , wiring
HTML code is On
