Chevy 1999 1500 Silverado reg.
Old Sep 7, 2008 | 6:04 PM
dguy72's Avatar
Default Chevy 1999 1500 Silverado reg.
when i hit 15mph my locks lock,thats right, but when i stop and put the drive in park they dont unlock whats the deal???????
Old Sep 7, 2008 | 8:31 PM
ukrkoz's Avatar
Default RE: Chevy 1999 1500 Silverado reg.
1. pull back on the signal lever all the way toward you/hold while performing next steps
2. put ignition in off/turn key to on/return to off/ hear locks switch lock-unlock
3. now you can program door locks/have 10 seconds to do so
4. press lock side of the lock switch once/turn automatic feature on/all door locks lock/none will unlock; do same twice/turn automatic feature to off/no locks will lock-unlock/auto unlocking will not work until auto locking is turned off.
press the unlock side of the lock switch on the door once to unlock the driver's door and lock all other doors
do same twice to unlock all the doors. all doors lock-unlock. this is factory setting
do the same 3 times to turn off the automatic door lock feature, no doors will lock-unlock.
turninf key toon exits mode.
dude, maybe i just need to copy you those pages. i, personally, am lost. but it's obvious someone has modified your auto door locks settings. pretty much, you want to turn auto feature to off/recycle ignition/turn it back to on, as factory preset is lock after 15 mph/unlock when key's pulled out.
sorry, my bad. they are not supposed to unlock. you have to shut down engine for locks to unlock. you are good if you are just in P.
Old May 4, 2009 | 11:52 AM
dguy72's Avatar
Default ???
do u got any websites that will help me dude?
Old May 4, 2009 | 9:37 PM
suzuki-guy's Avatar
reach over on the door when its in park and hit the unlock button problem solved...lol Problems like this make me laugh it could be worse your engine could blow up
Old May 4, 2009 | 10:26 PM
98white5.0's Avatar
LOL that's exactly what I was thinking! It's prolly the easiest fix. The button's what, less than two feet away? It is in arm's reach.
Old May 4, 2009 | 10:36 PM
suzuki-guy's Avatar
i would pay to have that be the only thing wrong with my truck
Old May 4, 2009 | 10:38 PM
98white5.0's Avatar
You and me both. (see rad. thread in a few min.)
Wingshot
Mar 23, 2015 11:00 PM
silver_fox_19642000
Nov 23, 2014 8:03 PM
westgl
Jun 29, 2013 9:17 AM
Gkdrumb
Apr 4, 2012 7:50 PM
david12601
Feb 19, 2011 7:25 AM
