Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Chevy Trucks, SUV's, & Crossovers > S-10 & Blazer
Old 10-02-2008, 08:10 PM
sejuron sejuron is offline
Default 2000 S10 misfire
I have a 2000 chevy s10 4.3 the injectors went on it and I replaced them with the conversion kit also replace the cap and rotor, vehicle now starts and ran, however it now misfires on mostly 3 and 4, it will start and idle fine and at first it runs normal even under higher rpm, however after a short bit it will start to misfire. the only codes i have is random misfire. does anyone have an ideas aboutwhereto go with this? Register today for free or log-in if already registered to remove this ad!
Old 10-03-2008, 01:30 PM
logeelandzr2 logeelandzr2 is offline
Default RE: 2000 S10 misfire
Did you replace the plugs and wires along with the cap?
Old 10-03-2008, 05:47 PM
the truck went stop running going down the road like no fuel, the fix was the injectors, i just did that while i was at it, it was not a problem befor do you think the wires and plugs would really have an issue even though they were fine befor
Old 10-04-2008, 08:16 PM
If you put a new rotor and cap on I would repalce the plugs and wires. Then everything will be new.
Old 11-01-2009, 09:41 AM
captainbone captainbone is offline
and then the problem may go away for a while, but when it returns let me know how you get it fixed. I've been dealing with a 98 blazer for 2yrs, few thousand dollars, and mechanics that have changed everything except fuel pressure reg. and pump so far. I can't wait till someone figures this out.
Tags
1995 , 2000 , 43 , aveo , chevy , high , malibu , misfire , misfires , missfire , rpm , s10
HTML code is On
