Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Brand Review > Audio/Visual Electronics
Old 11-03-2008, 08:09 PM
jordan61488 jordan61488 is offline
Default 2004 silverado door speaker install
wondering how to take the door panels off of a 4dr 25oo hd 2004 silverado? Register today for free or log-in if already registered to remove this ad!
Old 11-03-2008, 09:02 PM
shawnvw shawnvw is offline
Default RE: 2004 silverado door speaker install
pulltriangle trim from the top, pull the trim around door handle, remove lock slider. 7mm bolt behind the lock slider, 7mm under the armrest near the handle, remove push in clip at he front of the skin. If its an early year model, there is another 7mm at the bottom edge of the door, if its was built later in the year, there is a cap on a screw at the rear of the door, which has a T15 or T20 TorX screw in it.
Then just grab the handle of the armrest and pull straight up. pull the skind back a little, d\c the electrical connections, the light on the bottom and your done.
the speaker just clips in, but you may need a couple standard screwdrivers to get it out. One to push down on the clip, and the other to pry the speaker out
__________________
Old 11-11-2008, 04:56 PM
how do u take the lock slider off? n thanks alot by the way..
Old 11-13-2008, 12:12 AM
small pick or screwdriver. Go in from left side and pry it up
__________________
Old 09-20-2009, 01:12 PM
MikeHoncho MikeHoncho is offline
Default Speaker mounts?
I got the speaker out- thanks for that info. How do I take the factory speaker off of the mount? Is it glued on?
Tags
2004 , chevy , door , install , installing , panel , panels , rear , removal , remove , removing , silverado , speaker , speakers , traverse
HTML code is On
