Old Aug 10, 2015, 12:49 PM
See related guides and technical advice from our community experts:Browse all: Lighting Guides
Aiming the headlights
Old Nov 15, 2008 | 7:15 PM
BigThermometer's Avatar
Default Aiming the headlights
Hello.
Whenever I'm driving at night in my 2003 Silverado, I get flashed a lot. I've noticed that the lights are just aimed too high for low-beams (part of it may have to do with my truck sitting a little higher than normal). I looked in the manual for how to aim the headlights, but unlike my Cobra's manual, it doesn't mention anything about it.. or at least not that I could find. I took a very brief look under the hood but didn't see anything that might help me out.
Can someone explain to me how to do this?
Thanks.
2003 1500HD 6.0
Old Nov 15, 2008 | 7:19 PM
matador's Avatar
Default RE: Aiming the headlights
I am pretty sure they are not adjustable. I could be wrong as I have been wrong b4. Just ask my wife!!
Old Nov 15, 2008 | 7:57 PM
Haha
well I'm going to hope for someone to prove you wrong
They're aimed pretty harshly [8D]
Old Nov 15, 2008 | 8:35 PM
northey87's Avatar
You could have the dealer check them.
Old Nov 15, 2008 | 9:06 PM
ukrkoz's Avatar
there should be 2 torx head screws, on either side of the upper headlight, one almost right below the headlight fixture (forgot the proper name, sorry) and one recessed much deeper into it. one controls up/down, one does sidewise. park in front of your garage door, maybe 25 feet away, and do it.
if you have OEM setup and your lights are pointing high, batcha your rear shocks are tired and rear end sagged.
dude, you sound sort of freacking out with that truck. all kinds of piddly stuff going. what did you buy it for?
Old Nov 15, 2008 | 10:01 PM
Thanks, I'll give that a try in a bit.
You're right, I am pretty OCD sometimes.
But maybe you understand.. once you get a new toy, you just want to make it better any simple way you can. I guess I wouldn't consider myself as freaking out, but I admit I may be making big deals about nothing.
I bought this as a work truck really. After the purchase (about $16k), I went out and bought a Boss plow. I'm looking forward to a heavy winter. And also some hauling, but nothing major. I didn't intend on getting a flashy truck, but I saw this and loved it (plus it's an HD so that's probably better suited for the plow).
Old Nov 15, 2008 | 11:59 PM
It works. I don't know why I didn't think to try that one..
Thanks.
Old Nov 17, 2008 | 9:27 PM
ukrkoz's Avatar
because it did not look like an adjustment screw. i was amazed myself. GM has some sort of a fetish on torx bolts and nuts.
you welcome, glad it worked.
hey, out of kicks, find that long rod that lays flat on top of the headlight housing. then turn it towards you and pull up and out. the whole entire headlight comes out. sweet! so do marker/DRL lights below. very clever.
Old Nov 17, 2008 | 11:39 PM
Haha yeah it's an interesting design.. My first post on this forum was regarding replacing the daytime lights.. I had trouble getting the bulb out so I asked for help. It's been so cold recently though I think I'll wait until spring to try again.
Old Nov 18, 2008 | 5:39 PM
ukrkoz's Avatar
ORIGINAL: BigThermometer
no need to. there's a white plastic clip on the side of DRL assembly. you just pry it with a flathead, and the whole piece comes out. you might need to flash some light into the gap to see it.
as of the main headlight assy, i found it by pure accident. i'm like Cramer - if there's a lever or a button, i'll pull or push it. so i was standing there staring at that rod and then just sort of yenked it out - and cought headlight right on time, as it popped out. so i learned.
what you'll find about this truck that it is ****ty made, but easy access to most of all. except the fuel tank, i've heard. oh, yeah, and theATF pan removal..... yeah, that was sweet dreams indeed.[] otherwise, as far as you have set of oversized wrenches and torx heads - u good.
jclee1014
May 24, 2013 2:19 PM
David_lee1993
Nov 1, 2012 11:06 PM
slovcan
Feb 17, 2011 11:28 PM
Gunnywaldo
May 14, 2010 7:47 AM
Top
Follow Us
