P1351 IC Circuit High Volts, 2000 4.3 1500
Old Nov 17, 2008 | 11:07 PM
rwshaw's Avatar
Default P1351 IC Circuit High Volts, 2000 4.3 1500
Looking for a diagramor description of the ignition system fora 2000, 1500, 4.3L, 2WD truck. It stalled while driving and now has no spark. I am told the high volts code means there is an open. I replaced some parts (plugs, dist. cap/rotor, coil) and still no spark. The engine turns over and gas is getting to the plugs.I checked the fuses that I could(how do you test the big grey square ones?).Before I go buy an ignition module I would like to know what else could be wrong.Need help todo that. I don't know what other parts the system has (sensors?).
Any help would be really appreciated.
rwshaw
Old Apr 3, 2018 | 7:00 AM
Jim Hook's Avatar
Did you ever figure this problem out? I am having the same problem.
Tony_B.
12
Jan 23, 2016 4:15 PM
wing in atlanta
Aug 15, 2013 3:47 PM
wolfdogg
Sep 3, 2012 2:06 PM
baskervi
Jan 15, 2011 11:02 AM
cmd
Aug 20, 2007 7:39 PM
