Tires
Old Nov 18, 2008 | 9:02 AM
mcahoon's Avatar
Default Tires
Trying to make a decision on what size tires to put on an 08 reg cab 4x4. Was going to go with 315/70/17's, but tire man told me to try 285/75/17's, he says it will be about the same heighth, but a tad bit skinner and wld not rub as bad. anyone have this size on there trucks? Pics and thoughts please...
Old Nov 18, 2008 | 9:44 AM
Charms's Avatar
Default RE: Tires
First, this is how the tire size works.
The first number, lets use the 315/70/17 as an example, is the width. This tire is 315mm wide, or in inches, 12.4(315 divided by 25.4). The second number, 70, is actually a percentage of the first number, and that gives you the sidewall height. So 70% of 315 is 220.5, or 8.7 inches. So, now we have a tire that is approx 34.4" tall, 8.7*2+17, and about 12.4" wide.
The 285/75 is going to be narrower and about half an inch shorter.
I own a tire shop and if I had both of those sizes in stock right now i'd be glad to set them side by side and take a picture, but we are just starting out so we don't exactly have a lot of inventory.
If you have any other questions i'd be glad to answer them as best as I can.
Old Nov 18, 2008 | 10:29 AM
SuperTexan's Avatar
Default RE: Tires
Wont rub as bad? It dont need to rub at all.
Old Nov 18, 2008 | 11:21 AM
mcahoon's Avatar
Default RE: Tires
Thanks charm, i think ill go with the 285 since its a bit cheaper as well. plus wont have to cut any of the inner fender out!
Charms's Avatar
Default RE: Tires
Just go with the smaller ones if they don't rub, or get a lift kit.
I personally like the reg cab 4x4 lifted with big tires look.
edit: hehe you replyed while i was writing this post
JHarris8732
Nov 10, 2011 11:25 AM
scootr68
Jul 23, 2010 6:06 PM
bocajeff
10
Mar 31, 2010 12:41 PM
Andy
Jan 29, 2007 11:57 PM
