Platform: B-Body
police interceptor rear end ( posi? )
Old Nov 24, 2008 | 9:38 PM
ghosttiger138's Avatar
Default police interceptor rear end ( posi? )
i am tryin to figure out if a mid 90's police interceptor caprice has a posi trac rear end or is it limited slip or something like that. i thin the gears are like 3:42. can anyone help me out?
Old Aug 9, 2015 | 10:11 PM
69impalaconvharv's Avatar
Default Positraction rear end
You probably already have an answer to this, but here goes anyway. Posi-traction and limited slip differentials are different terms for the same thing. If it is a highway police car, it probably has 2.73 gears or lower thus giving it a high top end speed. If it is a city police car, it needs fast acceleration more than a high top end, so it would have a higher gear ratio such as 3.73 to one.
Harv
Old Aug 9, 2015 | 10:42 PM
or just turn the tires 1 turn and count the rotation of the driveshaft.
Old Sep 20, 2015 | 7:50 AM
WyrTwister's Avatar
With the transmission in N , chock the 3 wheels and the jack up the 4th wheel ( rear ) . Put jack stands under it .
Try to rotate the wheel manually . I think if it turns & the drive shaft turns , no posi . If it does not turn , I think you do have posi .
God bless
Wyr
Old Sep 21, 2015 | 10:14 PM
floor it while driving across your neighbours lawn.
fjbgwks
Jul 28, 2012 6:18 PM
holiday112284
Nov 10, 2011 7:28 PM
Nagromis12
Mar 13, 2009 2:39 AM
CMOS
Nov 1, 2008 10:38 AM
313hitman
Jan 28, 2007 1:17 AM
