Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Brand Review > Engine & Internal
Old 12-18-2008, 01:54 PM
kyleb15 kyleb15 is offline
Default Ticking noise coming from throttle body 93 chevy 1500 350
So the intake started leaking on my old 350. Replaced everything myself, put it back together and it started knocking. I guess we got a little bit of dust from the old gaskets in there.
We bought a new 350 from GM, it is like the base model, only 190hp. Put it all back together and it runs well. There is a ticking coming from the throttle body now though. It was never there before, it is very noticeable a idle and then kinda levels off as the RPM's go up. So yes it does get faster with higher RPM's but then just goes away. I used the broom handle method to try to listen exactly where it is coming from and it is definitely loudest at the throttle body. Is there some kind of a motor in the throttle body? Anyone know what this could be? It is very noticeable inside the cab.
Old 07-05-2009, 06:05 PM
docmsavage docmsavage is offline
Default Ticking noise too!
I have the same prob on a TBI installed on a 305. Making me crazy trying to locate the trouble. Nothing srong on engine internals. Have you found an answer???
M
Old 07-22-2009, 06:32 PM
silverado_svc_body silverado_svc_body is offline
the throttle body has 2 solenoids that meter the fuel going into the intake. one of the solenoids might have got bumped or internally injured causing it to tick.
Old 08-01-2009, 03:36 AM
zarifian383 zarifian383 is offline
Hey, I might have a fix, recently i replaced my sparkplugs on my truck, and after putting my spark plug wires back on I had noticed a small clicking noise coming from one side of the engine. Although it went away at higher rpm, it still bugged, and hey clicking is free at no extra charge.
So a friend and I went over it, and it turned out to be a spark plug wire to be out of shape, on all the way, but still not fully on, and the sound was it shaking from it being loose, and hitting the exhaust manifold repeatedly. I guess at hire rpms it doesn't have enough time to go far enough to hit the manifold before it gets jerked back.
Old 08-02-2009, 07:30 AM
mudmaniac's Avatar
mudmaniac mudmaniac is offline
Ride of the Month
May 2009
1987 Chevrolet K Blazer
My Garage
My guess would be one of the injectors is causing the noise.
__________________
MudManiac
95 Tahoe 383cu.in./350hp/425ftlbs
6" lift 16x35x16 Boggers
Old 08-03-2009, 12:02 AM
lukemoore646's Avatar
lukemoore646 lukemoore646 is offline
i have heard that before on tbi, as long as your sure its where its coming from and it runs fine i wouldnt touch it
__________________
Sometimes I wonder if engineers were put on this earth to make a mechanic's life misserable.
Co-founder of LO-maintenance:
The one stop shop when your tranny drops.
Old 11-07-2009, 12:43 AM
hilineracing hilineracing is offline
Default ya so...
On tbi's (throttle body injection) your injectors (not solenoids) are inside your throttle body. If you take off your air filter its a very noticable noise if you still cant hear it put your fingers on top of the injectors. I damaged my from rebuilding throttle body I didnt drop them but think the clean fuel going through the clean filter on the injectors cleaned the gum out of them and made them tick. same concept as causing internal damage from a motor flush with 150000 miles on it.
Tags
350 , 93 , body , bodychevy , chev , chevrolet , chevy , coming , engine , forum , k1500 , making , noise , throttle , ticking
HTML code is On
