Platform: J-body
P0301 code
Old Jul 24, 2006 | 12:04 PM
calwoodbutcher's Avatar
Default P0301 code
Just joined the forum and I have a question right off. 2000 Cavalier 2.2 has a problem. Car started running rough. Threw on the OBD and got the P0301 "cylinder No. 1 misfire". The plugs are new and look that way. The plug wires didn't look to good so I replaced them. I pulled the coils and cleaned everything real well. Put it all back together and guess what. Still runs the same. Anybody got any ideas?
Old Jul 28, 2006 | 2:12 PM
beckeruti's Avatar
Default RE: P0301 code
could be a injector
Old Jul 31, 2006 | 12:14 PM
My thoughts tend to lean toward an injector as well. Got a good question for ya. At what point does the computer analyze the cylinder fire? If it picks it up at the exhaust the injector could be the issue, if it picks up at ignition then it has to be electrical. Right?
Old Jul 31, 2006 | 2:07 PM
beckeruti's Avatar
the computer takes data from both kinda
takes data from the knock sensor and the O2 sensors
if u had a gas analyzer you could tell
or even a ignition scope u could check the spark pattern
switch the inector and see if the problem follows the injector
Ho Lee Chit
Feb 12, 2014 5:40 AM
ChevyDave007
Apr 9, 2013 2:38 PM
Mud_Truckin
Sep 12, 2009 7:32 PM
temills
Dec 16, 2006 6:35 AM
calwoodbutcher
Jul 28, 2006 5:14 PM
