Platform: Delta
Also Check out CobaltSS.net
harness code location?
Old Jan 1, 2009 | 7:47 PM
rafnel1969's Avatar
Default harness code location?
I have a 2005 chevy cobalt automatic, four doors. It started this morning, after I turned the engine on it shaked and smelled like rubber burned. then I noticed thatI gotthe engine light on. so I need to pull the codes, but I dont' know were the harness is located. does any body know?
any help 'll be apreciated.[:-]
Old Jan 2, 2009 | 1:35 PM
Bandit21's Avatar
Default RE: harness code location?
IF you got a scaner its on the drivers side closeest to the door under the dash if you rubber burning smell you might want to check the belt chances are theres a pully set up
Old Jan 2, 2009 | 7:30 PM
rafnel1969's Avatar
the weir part is tha it smells inside the car while the engine is on, not under the hood or in the engine area............ could be the transmission?
Old Jan 3, 2009 | 3:23 PM
Could be something as simple as oil burning if you have a gasket leaking. The fumes could be picked up by the air intake of your HVAC system.
You need a scanner to retrieve the codes from the car. people say that local your local Autozone or Partsource do this for free
Old Jan 3, 2009 | 9:58 PM
Bandit21's Avatar
Yea autozone will pull the p codes for free but depending on what the code is they cant go into them as far as most shops can. Is the smell like rubber or oil or a sweet smell and you say its just inside the car only with air/heat on or off or both?
Old Jan 3, 2009 | 10:02 PM
Bandit21's Avatar
if you do go to auto zone and you get a misfire code your going to have to go to another shop that is one of the codes that cant look into
Old Jan 4, 2009 | 7:23 PM
rafnel1969's Avatar
I really go and check it out.....but today while I was replacing the spark plugs. I accidentally I touch this little red thing that shows ontop left of the pic and all of a suden the engine never startedand all I hear is just a littlenoisylikea little engine trying to reactivate and a clank.
Old Jan 5, 2009 | 11:53 AM
Bandit21's Avatar
the little red cap is the jump post beacuse the batter is in the truck so thats your postive post i hope you didnt short anything out sending power into the wrong thing will make for a very $$$ repair
Old Jan 6, 2009 | 5:00 PM
rafnel1969's Avatar
i think I just did. the caris at the shop. they told me that it's a short, now they trying to locate it. thank 4 for your comments any ways.
Old Jan 8, 2009 | 11:19 PM
Bandit21's Avatar
yea anytime the main fuse is a good place to start looking chases are it got a fuse or it got the computer most of the wireing should be ok tho
trebreklaw
Jul 24, 2012 11:48 PM
twest1679
Mar 8, 2010 11:14 AM
warbler
Sep 15, 2009 5:01 PM
shovelaynut
Astro
Jul 8, 2008 5:09 PM
bri94lst
Dec 30, 2007 11:47 AM
