Platform: Delta
Also Check out CobaltSS.net
2007 cobalt radio
Old Mar 6, 2009 | 11:35 PM
ap4u06's Avatar
15 Year Member
Default 2007 cobalt radio
Recently noticed when i open the door and crank up, the radio resets all data like time, date. Anyone else having problems.Have heard could be a car battery going!!
Thanks,
Ap4u06
Old Mar 7, 2009 | 7:47 AM
Pull the radio out, unplug the conectors, and re-wire the power and ground to the radio. It should be red\white for (+) and a black driectly below it for (-). Attach a pair of wires to the connectors,(I use speaker wire) and run them down to the BCM, which is on the passenger side of the center console. Just pull the panel off, and then take off the 3 7mm bolts holding the white plastic thing on.
Put a 15amp fuse on the (+), and attach it to one of the big red wires at the BCM. There are 3 of them there, red\blk, red\wht, and I think just a red one. Any one will do.
For the ground, put a ring terminal on the wire and use a self tapping screw (shown below), and blast it into the bare metal below the bcm. That should fix your problem.
I have done about 5 of these in the last year and have yet to see one come back
Old Mar 9, 2009 | 1:16 PM
ap4u06's Avatar
15 Year Member
could it be that the radio be going?
Old Mar 9, 2009 | 5:35 PM
its possible.....But I have had about 90% success rate using this fix.
Old Mar 9, 2009 | 8:00 PM
qingchen000
Guest
Posts: n/a
This clock projects the time, date, or temp on the wall or ceiling http://www.liangdianup.com/clocks_1.htm some people call
it a ceiling clock but I call it a digital projection clock. I got the black one because at the time that was the only color
they had. But now they have them in black and also in white.
Old Mar 10, 2009 | 4:48 PM
wtf does that have to do with the clock on a car radio?
HyperParty
Cobalt
Apr 3, 2015 12:41 PM
dmar44
Cobalt
Dec 21, 2011 11:45 AM
adamant
Feb 15, 2009 8:49 AM
supersam
Cobalt
Aug 18, 2006 12:04 PM
