TrailBlazer 2002-2009
05 trailblazer gear is stuck in park
Old Mar 10, 2009 | 10:21 AM
romanlu's Avatar
Default 05 trailblazer gear is stuck in park
my 05 trailblazer is stuck in park. what is the problem?? please help husband is deployed and wondering if its going to cost me and arm and leg to repair
Old Mar 10, 2009 | 3:15 PM
rbarrios's Avatar
please let us know if your battery is dead.
Could be the solenoid in the shifter has malfunctioned.
If im not mistaken- the manual also has a procedure on getting the vehicle out of PARK in case the battery has failed.
in case the battery has not failed---
You may be able to shift it into neutral- and start the vehicle from there....
at least youll be able to drive it.
If you follow the procedure in the manual and still cant shift it-- then its probably related to some damaged linkage...
Old Jul 8, 2009 | 3:07 PM
shepdog25's Avatar
If you're parked on an incline without the parking brake on you migth have to push on the car to relief pressure on the trans
Old Jul 8, 2009 | 5:18 PM
rbarrios's Avatar
she never came back....
Old Jul 8, 2009 | 5:58 PM
G&b's Avatar
G&b
Default 03 trail blazer starts good but when hot cut off won't start back until cold please
Already check ground fuse relay box good, install a new swicth !!!! What can it be! Please help me! Fuel pump is good
Old Jul 8, 2009 | 7:55 PM
Make a new thread please.
mrpurplehawk
Jun 23, 2014 10:59 PM
mak1na
Apr 23, 2013 11:32 AM
BigblackHo3
Apr 5, 2013 8:54 AM
bdm408
Sep 11, 2008 8:55 PM
bdm408
Sep 7, 2008 6:24 PM
