Cigarette Lighter in 89 Chevy 1500
Old Mar 10, 2009 | 3:31 PM
steph66's Avatar
Default Cigarette Lighter in 89 Chevy 1500
My cigarette lighter was working then it went. I noticed when it was working that things that the adapter ends of things that were plugged into it would get very hot. Just wondering if anyone would know why this would be and where the fuse would be located to see if that is what the problem may be????????????????
Old Mar 10, 2009 | 5:20 PM
The fuse will be labeled CIGARLTR and it should be on the interior fusebox on the side of the dash. Its only accessible by opening the door.
Old Apr 5, 2009 | 1:23 PM
treadhead's Avatar
hey Brent, my 89 silv's fuse panel faces the seat, between the hood and parking break release. actually went out to make sure I wasn't imagining things when I had the dash out.
Old Apr 6, 2009 | 10:14 AM
therewolf's Avatar
OP, check your ground wire, it could be a bad connection to the dash/firewall. Otherwise,it sounds like you may need emergency surgery.
1) Find a way thru the firewall. All you need is enough for 1 wire.
2)Run a 12 gauge wire(with a 20AMP in-line fuse) from the positive side of your battery to the cigarette lighter(replacements are available at the parts store also) The spade connectors you need are generally blue female.(2)
3)make sure you run a ground wire to a metal ground on the underside of the dash or the firewall.
Gotta have those accessories,man.(BTW, this is how the Mayo clinic does it, yeah-yeah...)
Old May 18, 2010 | 9:43 AM
Texcowboy's Avatar
Default Cigrette lighter won't come out
I have 92 chevy pickup and cigarette lighter went out. I bought a new one to. Replace it with but can't get old one out. My fuses are good and so our my realys. I think I have a electrical short some where behind the dash due to face my cab light doesn't work buld I godod and lights that are suppose to come on when door ir opened don't come on either and cigarette lighter went out about same time any pointers would be big help thanks.
Old May 18, 2010 | 6:54 PM
desrtrat's Avatar
the power adapters for cel phones, I pods, lap tops, and so on, will short out/over heat because the cigarette lighter plug in most older vehicles were never designed for that type of plug.. if you look at a newer vehicles power port inside it is designed differently from your cigarette lighter. most auto parts stores sell the cigarette lighter that will work for both..
good luck
Old May 19, 2010 | 3:31 PM
Texcowboy's Avatar
I bought new Cigarette lighter still won't heat up I also put test light on plug and it has no power. The light that is suppose to come on when ash tray is opened doenst have power either. Guessing I have a short some where any ideas on where this might be
quentusrex
Jan 6, 2016 1:23 PM
sabinas
Jan 4, 2010 6:10 PM
MACK5150
Mar 8, 2009 4:47 PM
cle19
Dec 2, 2007 1:46 PM
harryanderson
Jan 11, 2007 12:33 AM
