Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Brand Review > Detailing
Old 03-23-2009, 11:00 PM
maximan1's Avatar
maximan1 maximan1 is offline
Default Engine detailing?
I really want to detail my engine, and I was wondering which was the best and easiest way to go about this. Should I use steam cleaning or chemicals? Thanks, Max. Register today for free or log-in if already registered to remove this ad!
__________________
www.olgapetrovart.com
Old 03-23-2009, 11:20 PM
Ride of the Month
April 2009
2000 Chevrolet Blazer
My Garage
Super clean and a long narrow car was brush is what I use on the engine itself. Then I just go over the rest with a soapy shop rag. It takes time, but thats the best way.
NEVER use a pressure washer. EVER. You can damage underhood liner and you'll blow off and/or damage insulation around the manifold and the inner fender flaps.
Old 03-24-2009, 12:58 AM
maximan1's Avatar
I would have to put WD40 on the wires to keep them from shorting out or such, right?
__________________
Old 03-24-2009, 10:41 PM
Ride of the Month
April 2009
My Garage
I have never done it. No problems...
I'm not sure exactly what the relative conductivity, resistance, and capacitance of water is, but I don't think it can handle current well enough to provide a high amperage short.
Bottom line is, I wouldn't worry about.
And WD40 isn't the greatest of insulators....
Old 03-31-2009, 11:01 PM
tjstockton tjstockton is offline
Ride of the Month
April 2009
wd40. know where they got the name for that? the company was trying to come up with a product for water displacement, and this was their 40th attempt. i know that has nothing to do with this, but it's just a small thing that one of my professors told the class recently. thought i'd share.
__________________
-lil tim
Old 04-01-2009, 09:30 PM
Ride of the Month
April 2009
My Garage
Some say WD40 is called WD40 because it has a water displacement value of 40.
But yes, it is the 40th formula.
Old 04-30-2009, 09:20 AM
OnDaGround's Avatar
OnDaGround OnDaGround is offline
Quote:
No, no, no (wd-40... what?)... You can gently spray the engine bay area. You should not be spraying it in hard or drenching everything. All the connectors have seals/grommets in them. But still you don't want to spray it in there at full blast.
When I used to detail back in the day I would apply a little bit of tire shine on a rag and whipe down any black plastic pieces. It makes it look 100 times cleaner. Like I said, just apply it to a rag and give everything a shine. You can so the same with any black kick panels or door trims on trucks or cars. The only disadvantage to that is; the coating must be lighter and once it gets wet you will see water streaks down it (unless it's washed completely off). So if you do use it on the outside you will need to apply it every once in a while. It makes the car look a ton better and eliminates any fading... but it does require some up keep.
__________________
"Tell your boyfriend, if he says he's got beef... that I'm a vegetarian and I ain't F___king scared of him."
1998 Malibu Ls -- Daily Driver. High Quality audio mods only.
1993 Saturn SC2 -- It would surprise you --
CAI, Pacesetter Header, Easterns h/f Cat, PaceSetter CatBack, walbro 255lph racing fuel pump, Apexi SafcII management system,Plx M-300 Wideband Controller, other misc performance mods.... mini 2100lbs road warrior
Old 05-05-2009, 08:36 PM
maximan1's Avatar
I detailed my engine. Looks great.
__________________
Old 05-05-2009, 11:30 PM
Ride of the Month
April 2009
My Garage
Pics?
Old 05-06-2009, 12:13 AM
Mike Sigmond's Avatar
Mike Sigmond Mike Sigmond is offline
ROTM Coordinator
2003 Chevrolet Silverado 2500
Yea, pics would be cool! I always use a bottle of that good engine degreaser, let it sit for 15 min then lightly use a hot water pressure sprayer to clean it off. I am just very careful around anything water can get into. I do this about every 3 months along with the air filter cleaning. I remove it and bag off the maf & intake area with a rubber band so the water wont get in there. I check the electrical connections about once a year and clean & add anti corrosion gel as needed.
__________________
For the wife - 04 5.3 Tahoe Black, fully loaded.
Tags
53 , 57 , armor , avalanche , chev , chevrolet , chevy , degrease , detail , detailing , disadvantage , engine , impala , kit , silverado , washed , wd40
HTML code is On
