2003 heated seat turn on/off randomly
Old Apr 5, 2009 | 10:38 AM
nolefan97's Avatar
Default 2003 heated seat turn on/off randomly
My heated seats turn on/off on there own. How do I fix this?
Thanks
Old Apr 7, 2009 | 11:23 AM
PartsTaxi.com's Avatar
Former Vendor
Do they turn off randomly while in use, or intermitantly not work. IIRC, if the seat belt is not connected, the seat heaters will not operate on that year.
Kevin Cassimore
Old Apr 8, 2009 | 5:38 AM
nolefan97's Avatar
Kevin,
They just come on while I'm driving with the seat belt on.
You can see the lights on the heat switch go on for about 30 seconds and then go off on their own. It does this over and over.
Is there a sensor in the door I can replace??
Old Oct 14, 2009 | 2:52 PM
mcatron12's Avatar
Default 03 heated seat issues
I also have experienced the driver seat heater going on and off, and clicking under the seat. Is there a way to check if sensors are bad?
Old Oct 27, 2009 | 11:44 AM
ksimmons95's Avatar
Angry 2004 Suburban w/ Seat Heater problems
I have the same problem, although it usually just turns off after 45 seconds. The dealer wants $900.00 to fix the problem and says the capacitor is failing? WTF?? There has to be a cheaper fix. My fuses look good, but something is tripping the heater. I live in Houston and only use the heaters about 2 months out of the year. Any help is appreciated.
Old Feb 20, 2010 | 2:54 PM
marv's Avatar
has anyone ever figured this out,I have the same problem, 2004 tahoe, also having the problem with electric forward/backward control on side of seat going the opposite way? help
Old Feb 21, 2010 | 6:06 PM
mcatron12's Avatar
In addition to the above, my passenger side window will no longer operate. Could this be a driver door module?
Swippe
Mar 15, 2013 10:05 PM
eljicio
Apr 2, 2011 9:34 PM
Mr. Vann
Nov 25, 2009 7:24 PM
2004TahoeZ71
Apr 1, 2009 1:49 PM
cactusjack
11
May 7, 2008 10:03 PM
