Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Chevy Vans & Minivans > Astro
  #11
Old 05-24-2009, 11:39 PM
Thumper_ehhhhh's Avatar
Thumper_ehhhhh Thumper_ehhhhh is offline
oh i like those rims. I see lots of posibilities with that cargo van. have fun with it. Just dont forget to post pics. Register today for free or log-in if already registered to remove this ad!
__________________
Trevor
2004 Suburban LS 4x4
2001 Astro LS
2005 Kodiak 25QB HTT
Reese dual cam weight distrubution
Prodogy P3
Pentax K100D
DW
DD 11
DS 7
Dog 5
Myself Older than dirt
  #12
Old 07-12-2009, 11:00 PM
BigFish246 BigFish246 is offline
Default 1993 passenger from Doylestown PA
1993 passenger. Lasted for me 9 years (15yrs total); 156,000 miles. Went up and down the east coast a few times hauling motorcycle inside and with trailer.
Transmission was slipping, and the motor over-revved. Blew it up.
And there it is getting towed away.
  #13
Old 07-28-2009, 10:27 PM
h2kawa h2kawa is offline
Default My astro
This is the day I bought it. I will post some more recent pics soon.
File Type: jpg 7354129072_245675460_IM1_02_565x421_A_562x421.jpg (74.0 KB, 4 views)
  #14
Old 07-29-2009, 12:58 AM
1Gary's Avatar
1Gary 1Gary is offline
Quote:
Looks good.Welcome to CF.Hope to see you and the van soon.
  #15
Old 08-26-2009, 09:39 PM
ADVAstro ADVAstro is offline
Default The ADV Astro
Here's some base shots of my Astro. It's a 98 LS Rear Wheel Drive with the limited slip Diff. I've installed a ShadyBoy Awning originally designed for the VW Campers. Otherwise it's pretty much stock, other than a new radio.. but things are about to change.
This is my ADVenture Astro and is being built as a support vehicle for my ADVrider Motorcycle adventures. Sometimes the roads get real bad and the hitch tends to drag. The solution is a small lift and some bigger tires.
I'm installing a 2" lift from www.Overlandvans.com to run LT235/75/15 BFG All Terrain tires. Also on the worklist is a set of airLift springs, which are airbag assist springs that mount between the leaf spring and the body, with an onboard compressor to adjust the ride height. Also adding a Safari roof rack of some sort and I'll be building a chuckbox that fits in the back.
I'll start a new Post when I get going on the lift.
ADV Astro
  #16
Old 08-29-2009, 05:45 PM
Default ADV Astro's 2" lift is done
Put an OverlandVans.com 2" lift on, LT 235/75/15 BFG All-Terrains, Rancho RS5000 Shocks.
Front is a full 2" higher, rear got 1 5/8". I made a post detailing the lift. It's not too bad a job. Took about 6hrs.
__________________
Ethan
98 LS - The ADV Astro
Build Photolibrary at:
http://s9.photobucket.com/albums/a72...7/ADV%20Astro/
  #17
Old 08-30-2009, 01:51 AM
Question lift kit
Just wondering how the ride is after the lift. I`m thinking of doing the same to mine. Looks great bud !! H2
  #18
Old 08-30-2009, 03:08 AM
1Gary's Avatar
Depends on how high you go and what you do to get there.Add-a-leaf to rear springs give you firmness but you have to have steel rear springs and not the fiberglass ones.(later than 1994).Overlands sells rear springs that have been reports to improve the ride and still lift the vans.Overland sells also lift front springs which require a ball joint relocation for RWD's.You can go to 2"(I think) before you need to buy the steering link extension.I have seen guys use schedule 40 tubing welded to the sub frame as spacers using the stock body mounts up to 5 1/2" of lift and have a really good ride because the stock springs are being used.What is common is the 3-4" lift with a combination of springs and blocks and spacers from Overlands.
Like I said it all depends on what method you use and how high you want to go.Please get back to us with your plans and surely pictures are appreciated.
Thanks,
Gary
  #19
Old 08-30-2009, 10:27 PM
The ride is the same, just a better view. The springs did not change. I have the Rancho Shocks on now, certainly an improvement over the worn out Monroe Selectrac units.
__________________
Ethan
  #20
Old 10-17-2009, 11:32 AM
MarlboroMan MarlboroMan is offline
Here is mine. It need to be repainted, and it is just past 100,000 miles now.
Can I not add more pics with out creating a new reply? When I get it repainted I want to do the A-Team version!
Tags
1991 , astro , awning , ball , boy , chevy , joint , pictures , rims , safari , shady , sprinks , wanted
HTML code is On
