i want to beef up my 03 suburban suspension
Old Apr 22, 2009 | 1:24 PM
davidstereo's Avatar
Default i want to beef up my 03 suburban suspension
Anyone on here know a way to make the rear suspension stronger on the rear of my suburban? I want less sagging with a load and maybe about an inch of lift if possible. I have new front torsion bars (as high as they will go) and also spacers on top and bottom of the rear springs. Problem is that after my first trip with a 3000 pound load the rubber spacers are back to about factory ride height. I wanted tp put 2500 springs on it if they fit. does anyone know if they will? Thanks, Dave
Old Apr 22, 2009 | 6:44 PM
what about air bags
http://www.ultimateautoaccessories.c...OD/AIR/4108__1
Old May 17, 2009 | 10:51 PM
Default maybe
the air bags are very expensive after u buy tanks and all they tsill wont lift the raer where i need it. ANyone have any more ideas?
Old May 19, 2009 | 11:17 PM
DeeZ's Avatar
Ride of the Month
August 2009
I'm not sure if they make Add-A-Leaf packs for suburbans but if they do that would def be your best bet. Do some research and see if you can find one.
Deez
Old May 19, 2009 | 11:20 PM
suzuki-guy's Avatar
You could look into some stiffer 3/4 ton springs from the junkyard.
Old May 20, 2009 | 2:09 PM
does anyone know if the 3/4 ton springs will fit on my 1500?
Old May 20, 2009 | 2:41 PM
i just looked the 3/4 ton springs on line and they have leaf springs. i think i may go with the coil rite air bags from firestone. anyone have any luck with these?
Old May 21, 2009 | 2:26 PM
SabrToothSqrl's Avatar
Default well
so beef up as in lift?
you could try a lift kit.... SkyJacker, RockKrawler, Rubicon Express, Claytons, etc...
in the jeep world we weld trusses to the axles for strength.... break out a welder and some metal lol!
Jarwade
Jul 10, 2020 3:01 AM
Simon-Pierre Lacasse
Mar 8, 2014 7:18 PM
akabavah
Avalanche
Oct 10, 2009 9:54 PM
elijahrw
Sep 24, 2008 2:27 PM
