Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Brand Review > Audio/Visual Electronics
Old 04-30-2009, 12:13 PM
rivereye rivereye is offline
Default Aftermarket Audio: Watcha got?
I have a few ideas I'm bouncing around, because my O.E. sound system is on it's last legs now.
First, generally, when you upgrade to more power for tunes, you may be looking for a larger or higher amp alternator. Does anybody have a system which has worked well(or poorly) for them? How big an alternator is good, what's too much?
What audio brands do you use and prefer?
Which heads,amps,subs, and speakers are kickin'?
Anyone have any good wiring diagrams?
Old 04-30-2009, 01:43 PM
Ride of the Month
April 2009
2000 Chevrolet Blazer
My Garage
Moving to the AV Electronics section.
In my Blazer, I have MTX subs with a Sony system and I have not been dissapointed. The Sony stuff is comprised of 6" Sony door subs and door pillar mounted tweeters. I also have Sony 4-ways in the dash and soon will have Sony 6x9s in the back doors.
Even though the Sony equipment is cheap, it sounds unbeleivable. I'm actually running it through the stock Bose amp, which probably explains the exceptional sound balance. Its not the very best equipment out there, but for the price, the system I'm using is unreal.
Old 04-30-2009, 04:27 PM
samger2 samger2 is offline
I've found that in my past builds I've been the most pleased with Infinity speakers for my fronts and/or rears, and when it comes to subs I prefer JL Audio...but in my Cherokee I needed some slimline subs so went with Rockford Fosgate. As far as amps go, I've been most impressed with either JL Audio for mono amps to push my sub, or alpine amps to push my other speakers.
Here are my current setups in my other vehicles:
1997 Jeep Wrangler Sport:
speaker box built INTO the rear seat
JL mono amp mounted under the seat:
Then I mounted my Alpine amp for fronts and rears inside console
Here's my 2000 Jeep Cherokee:
Amp placement under the rear seat
Old 04-30-2009, 04:44 PM
Ride of the Month
April 2009
My Garage
I need to make an enclosure like that for my Blazer. My box is slightly too small for the space I have it in.
Old 04-30-2009, 04:55 PM
in2pro in2pro is offline
Damn... all I got is that little dinky cable that connects and Ipod to the factory radio.....
__________________
2007 LT White, 20's, Painted Calipers, mostly stock but I like her that way...
Old 04-30-2009, 10:18 PM
I got lots of good info from Rockford Fosgates website...they have a little program that will help you to calculate what kind and size box to build based upon the speakers you have and the air space needed. Also www.caraudio.com was a great resource as well.
Old 04-30-2009, 10:33 PM
shawnvw shawnvw is offline
I've got an 02 trailblazer. Everything in it is Pioneer. I can pound the subs as hard as I want and it doesn't seem to affect it. Door Speakers are also pioneer, although they blew quite easily.
4 channel and mono block amp in the small cubby
Capacitor.....only a half farad, but it was given to me at the time
The Sub....Still not 100% finished at this time....I didn't know how to clean up the look of it, so I added a speaker grill to it and put it off. The box is built into the fender well behind that panel. The sub I used was a Pioneer Shallow-Mount 10".
http://www.pioneerelectronics.com/PU...low/TS-SW1041D
Everything hidden when closed up. Sounds pretty good for just 1 sub.....
__________________
Old 05-01-2009, 11:04 AM
Nice setup...I like how you built that speaker into the side cargo area...looks clean and fairly hidden.
I did something similar in my Cherokee before I built the box you see above
Old 05-01-2009, 12:30 PM
cams 98 silverado's Avatar
cams 98 silverado cams 98 silverado is offline
i got a jensen flip out monitor head unit, gps wired in and the whole works. i got kicker components all around and a phoenix gold 1700 watt amp pushing a 10 in. kicker l7 in a kicker ported box under the back seat behind the driver where no one sits. its hooked to a 5 farad capacitor and its own stand-alone battery that gets charged by the truck via isolator. all my accessories go to the extra battery. this summer im going to try some fiber glass work on the A-pillars and slap in some gauges and tweeters. im also thinking about doing some carpet work but its an idea.
__________________
green machine.
1998 chevrolet silverado ext. cab
me in the driver seat
Old 05-04-2009, 09:59 AM
OnDaGround's Avatar
OnDaGround OnDaGround is offline
I like the cap in the sneaky storage bin. That is real clean. Good job bro. I don't have a pic of mine.
My setup:
Two 12 inch RockFords... the previous ones (they are better quality then their newest stuff)
1000 watt kenwood amp
Rockford Cap
Pioneer P8mp head unit.
__________________
"Tell your boyfriend, if he says he's got beef... that I'm a vegetarian and I ain't F___king scared of him."
1998 Malibu Ls -- Daily Driver. High Quality audio mods only.
1993 Saturn SC2 -- It would surprise you --
CAI, Pacesetter Header, Easterns h/f Cat, PaceSetter CatBack, walbro 255lph racing fuel pump, Apexi SafcII management system,Plx M-300 Wideband Controller, other misc performance mods.... mini 2100lbs road warrior
Tags
07 , 08 , 1996 , aftermarket , amp , audio , cab , chevrolet , chevy , door , ext , header , placement , silverado , speakers , traverse
HTML code is On
