Platform: Delta
Also Check out CobaltSS.net
Keyless entry programming
Old Aug 17, 2006 | 1:58 PM
sadalius's Avatar
Default Keyless entry programming
I just purchased a 2005 cobalt coupe. The dealer was only able to provide me with one keyless entry remote without having to order and program a new one. I found a site that I can get a new one pretty cheap but I don't know where to begin with programming it to my car. I ran across these instructions for a Tahoe and was wondering if they would work on the cobalt as well.
Programming Instructions:
1. Close all the vehicle doors.
2. Insert the ignition key into the ignition lock cylinder.
3. Press and hold the door unlock switch.
4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
7. Repeat the previous step to program up to 4 transmitters.
8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
9. Operate the transmitter functions in order to verify correct system operation.
If this won't work, could someone provide the correct instructions?
Thank you for any help at all!
J Bryant
Old Apr 24, 2007 | 12:58 AM
Matteo's Avatar
Default hgf
6543
Old Nov 9, 2013 | 1:50 PM
autoexpert's Avatar
There are many baseless instruction on net regarding key fob.
But i recommend for chevrolet:
Chevrolet Keyless entry key programming instructions - ProgramKeyFob.com
SeventyZ28
Dec 1, 2008 8:44 AM
jjsimmons
HHR
Nov 27, 2008 1:54 PM
93Miata
Astro
Mar 1, 2008 1:49 AM
plasmud
May 11, 2007 6:39 AM
davidchevy
Dec 16, 2006 6:15 PM
